2002 lexus gs300 vsc and abs lights been on
iModerate
You will need to have DTC(s) (Diagnostic Trouble Code) read from the ABS system, the issue repaired, and then the DTC cleared which will turn of the light.
A generic OBDII Scanner will not read the ABS, a better tool is needed. Once you have the DTC you can search for a solution for it here.
TonY_G
07-28-07 12:47 PM
