300K miles
Old 12-19-11, 12:04 AM
  #46
pingu
pingu's Avatar
Originally Posted by GokuSSJ3
This statement is half truth, but worded poorly. You can switch between dino and syn oil any time you want during the life of the car and dino oil touches the exact internal parts as syn oil in a motor. In the OP case, it IS a waste of money to switch to syn oil at 300k, especially given the fact that dino oil got him to 300k. Syn oil doesn't break down quickly like dino, thus being able to clean the engine and remove deposits left behind by dino oil and go 8-10k on oil change intervals. That's why a lot of people complain that "syn oil caused my VC gaskets to leak". It didn't cause it to leak, they already had a weak/worn VC gasket, but the crud left behind from dino oil was able to "seal" the problem areas, not causing it to leak. Once changed to syn oil, the high quality Group III or higher oil is able to clean the deposits in the engine, thus removing the deposit/sludge "seal" that stopped the oil from leaking, now all of a sudden you have a leak.
This is exactly what happened with the OP. If the car was already smoking before hand, he would've never made this thread IMO. This happened after the syn oil was used. I say switch back to a dino oil and change out every 5k. Syn oil is a waste of money, especially at your mileage.
Listen to this man and learn more about oil before listening to people on the internet. I wouldn't trust anyone who tells you that dino oil is thicker than synthetic...
I would suggest reading an article on ferrari chat. It has changed my views on the types of oil that I run.
http://www.ferrarichat.com/forum/faq...=haas_articles
Old 12-19-11, 05:49 AM
  #47
shvc1991
shvc1991's Avatar
Lol damn... Would have never guessed your car has 300K miles. Mine looks nowhere near as good and I hit 231K yesterday. I have major road rash on the front bumper.
Old 12-19-11, 07:59 AM
  #48
RamAirRckt
RamAirRckt's Avatar
Good article, thanks!
I am puzzled by Amsoil's website, they typically are pushy on the 0W30 oils, but for the 98 GS4, they don't recommend the 0W30, they recommend the 5W30 (stock oil spec). Odd.
After seeing the bearing clearances on the GS4, I would keep closer to the stock weight if at all possible, the bearing clearances aren't wide as barn doors like an old 70's Chevy 350. They are super super tight, tighter than any production engine I have ever seen.
I don't think I would go to a xW40 weight unless you KNOW you are going to push high temps.
Old 12-25-11, 09:45 PM
  #49
Azlex90
Azlex90's Avatar
man im sold on def getting the lexus now nice car by the way.
Old 01-02-12, 03:15 PM
  #50
lisarayesman
lisarayesman's Avatar
300k...WOW!!!!
Old 01-03-12, 10:21 AM
  #51
USMCLexus
USMCLexus's Avatar
It's a Lexus. Not surprised.
Old 01-03-12, 10:28 AM
  #52
LexiBlue
LexiBlue's Avatar
keep riding if u take care her she will take care of u. What oil do u use
Old 01-03-12, 12:45 PM
  #53
socal72
socal72's Avatar
+100 I believe in this wholeheartedly!
Old 01-03-12, 01:19 PM
  #54
PushinLEX
PushinLEX's Avatar
Congrats on the 300K milestone!
As to oil, I just use Mobil 1 5W-30 and call it a day. I use the extended performance and change my oil every 7-8k miles. Works fine. No problems, no reason to make any changes.
Old 01-03-12, 02:29 PM
  #55
RamAirRckt
RamAirRckt's Avatar
Most of my cars over the last few years have seen 250-275k and I have kept them on a steady diet of Mobil 1 Diesel 5W30 or 5W40 or Shell Rotella T (synthetic and dino) 15W40 or 5W40. I wear the car are far before the drivetrain....
Being consistent can't ever hurt, M1 far exceeds the SH (I think) spec on these cars when new. So you aren't going wrong.
Old 01-03-12, 02:37 PM
  #56
Teasy010
Teasy010's Avatar
That's why I love Japanese cars... They run forever!
Old 01-03-12, 03:01 PM
  #57
RamAirRckt
RamAirRckt's Avatar
My American cars are the ones that have seen 250k (94 Fleetwood with 3.42 gears factory), 270k (90 Aerostar E4WD, eats transmissions every 100k) and 275k (91 Bonneville) miles, and the ones I have now are at 176k (00 Park Ave Ultra) and 193k (99 Suburban K2500 454), all with very little drama and cost to keep them running good. Well see how the GS lives compared to them. I am at 146k now. Not one of my cars has had to have the engine opened up at ALL in that many miles, and only that Aerostar had the transmission problems, but that was before and after I had it. Ford's and reliable transmissions.... not a good combo. Engines run forever though.
I have seen too many Toyotas (Matrix and Camry) not make it past 150k on stock engine.... I am hoping the GS4 will show me that it will laugh at that.
Old 01-03-12, 09:00 PM
  #58
breadbeat
breadbeat's Avatar
Im at 212K on my GS400 and running smooth as butter. Purchased the car at 170K and switched to synthetic and the valve cover gaskets started leaking. Replaced the gaskets and continued to run synthetic (Mobil1 5w30 high mileage)and no more problems. I am sold on the lexus brand....The ones built in Japan, not in Kentucky.
Old 01-03-12, 11:43 PM
  #59
SlowGS4
SlowGS4's Avatar
I too do the same with mobile 1 5w-30 extended every 6-8k miles, with the 10k mile xtended guard oil filter. about to turn over to 200k miles.
Old 01-04-12, 08:21 AM
  #60
RamAirRckt
RamAirRckt's Avatar
when did they start making in KY?
Quick Reply: 300K miles
