Some new pics of the Lexus
Old 01-30-12, 06:27 AM
  #61
Hardrvin
Hardrvin's Avatar
Originally Posted by adamgamz
This is what I found out on my journey to building a reliable stock 4 speed auto trans.. The Aristo unit is very similar to the Supra auto but it has 2 extra solenoids, and the valve body is a little different. I was going to build it with Titans builder but he said I would want to install a AEM or other stand alone that can control the line pressures and shifting of the transmission. By doing so I would lose my push button shifting and the trans would be experimental, I might have to pull it a few times for them to get it perfect. I was told by running a built Aristo trans on a stock ECU I would probably burn up the transmission. With that said there was no benefit to building the Aristo 4 speed so I decided to go with the proven 1000 RWHP Titan Supra tranny, the shift linkage and drive shaft bolted right up as I got one with the 3 bolt flange. I should have my car up and running this week with the new set up! Looking forward to blasting into the 10's.
Arg, definitely not what I wanted to hear. I actually talked to Titan on the phone to discuss getting same thing built up for me.
I'm really wanting to avoid going stand alone. I'd like to maintain stock cold weather start up, not carrying a laptop to tweak and so forth. Ugh.
Anyone want to find me a wadded up Auto Supra TT that I can buy the part out
Old 01-30-12, 09:09 AM
  #62
adamgamz
adamgamz's Avatar
It';s all in the tuning, get a good tuner and the cold start isn't bad at all. I wasn't concerned with the stand alone, my problem was I kept burning up bearings in the bottom end due to a blocked oil galley. That's why I just started over with an entire new drivetrain.
Adam
Old 01-30-12, 08:47 PM
  #63
bankaiGS
bankaiGS's Avatar
Very nice build brotha I'm doing the Aristo swap in may any issues you can let me know of I have 2nd gen gs as well the swap I'm getting is coming with motor tranny ecu and harness but I'm also getting an aftermarket bov,intercooler and fuel system
Old 01-31-12, 02:39 AM
  #64
adamgamz
adamgamz's Avatar
no point in upgrading the fuel, you need the stock Aristo MAF meter. Also my car would always spark knock on the stock MAF meter and stock ecu, I think it was due to the high octane fuel over in Japan, the ecu was tuned for JSPEC fuel so even on 93 octane I wold hear a little spark knock, that is one of the reasons I went back to a stand alone.
Old 05-16-12, 07:14 PM
  #65
adamgamz
adamgamz's Avatar
I thought I'd give an update, my car has gone through the next round of mods. I just filled her up with E85 for the 1st time tonight, looking forward to tuning tomorrow. The new mods that have gone on in the past few months are: Precision 6766 .81 turbo, modified header with twin wastegates, exhaust resonators to keep the noise down, 1200 cc injectors, twin Aeromotive pumps, Titan Stage 2 automatic trans with Titan 3500 stall, NX 75 shot of nitrous, AEM stand alone to control the shifting as the Haltech cannot do so, twin trans coolers, trans temp gauge, remote trans filter, Supra non vvti intake / TB, BFG drag radials, TRD LSD rear, replaced the GS400 rear with the GS300 diff for the auto. Will be hitting the track soon!
Old 05-16-12, 07:49 PM
  #66
TTurboPimp
TTurboPimp's Avatar
Adam, youre gonna need bigger injecotrs to take advantage of that E85 bro. Throw some ID 2000's in that puppy and crank up the boost.
Old 05-19-12, 09:48 AM
  #67
adamgamz
adamgamz's Avatar
I just upgraded from 1000 cc injectors to 1200cc injectors. The 2000's suck for low speed driving. The bigger you go the more drive ability you lose. 1200's are sized perfect for a PTE6766 .81. That turbo will max out at 850 RWHP or so, the 1200's will handle that on E85.
Old 05-19-12, 04:02 PM
  #68
LexiBlue
LexiBlue's Avatar
nice ride clean whats under the car cover?. Never mind Viper
Old 05-20-12, 02:55 AM
  #69
tan24
tan24's Avatar
man nice ride looks clean!
Old 05-20-12, 03:24 AM
  #70
Lextasy671
Lextasy671's Avatar
a lot of power in your garage. dang..
Old 05-20-12, 06:47 AM
  #71
adamgamz
adamgamz's Avatar
Thanks guys, the Lexus feels really stron, last night I took it for a drive at 25 psi on E85, it pulls really hard and gets a little scary hitting 2nd gear. Even with the drag radials it gets sideways hitting 2nd.
Old 05-27-12, 05:23 PM
  #72
adamgamz
adamgamz's Avatar
Well I broke my 3rd Titan built A340E running E85, my new TH400 will be here on Tuesday, its the Stage 3 SP400 with the trans brake, I plan on adding a gear vendors overdrive unit at a later date which will make it a 6 speed ratchet shifting auto.
Old 05-27-12, 06:39 PM
  #73
TTurboPimp
TTurboPimp's Avatar
I had that exact same set up in my TTGS4 for awhile, damn near unbrakeable, but I didnt care for it for street driving.
Why not go 6 speed?
Old 05-30-12, 07:10 AM
  #74
adamgamz
adamgamz's Avatar
Why not go 6 speed?
I had the 6 speed but I want to go auto with a trans brake for the track. With the 6 speed I wasn't happy with the length / throw of the shifter, as you may be aware in order to make the 6 speed work we have to make our shifter 50% longer than a stock shifter which creates a much longer throw, also I was never happy with the pedal placement of the clutch or the looks of the center console area from the extensive modification for the 6 speed, not to mention the high cost of the clutches. I will probably add a gear vendors so I will have a 6 speed TH400 and can cruise at 80MPH at 2,000 rpm.
Old 06-04-12, 08:40 PM
  #75
adamgamz
adamgamz's Avatar
Almost done with the swap, just waiting on the driveshaft and some finishing touches.
Quick Reply: Some new pics of the Lexus
