got a quick question.....im trying to install my visors and just wanted to make sure im doing it right. is the double sided tape suppose to stick on the rubber part or the window rail
thanks!
vvvvvvvvUPDATEvvvvvvvvvvvv[IMG]http://i276
i couldnt get it to sit properly if i taped it on the rubber trim so i decided to do something else. i cut off the metal clips and just taped the visor on the metal window rail. see photo below. to some, it may not be the best method, but i like it. thanks everyone for the replies.
They should stick on the rubber. The 2 claps on the visors pretty much set them in place where they should go and the double sided tape secures them to the window. Do a dry fit testing with them first so you can see how everything lines up. Then pull the film on the double sided tape just enough to be able to do a gradual pull of the film and push as you work your way to the edge of the visor. Take your time once they're stuck you can't readjust them!
Thanks for the replies. Leaving the rubber seal alone, I pushed the visor down as much as it could and I can only get the tape on the visor to line up with the rubber trim. I will try again tomorrow and ill post pics also.
