MPX-B fuse
Old 12-27-11, 10:59 AM
Toyboy300
Toyboy300's Avatar
Default MPX-B fuse
I've searched previous threads but couldn't find anything to solve my problem.
Something is draining my battery. My mechanic tested and found the fuse under the hood (1998 GS300) labeled MPX-B is drawing current constantly. Does anyone know what this 10A fuse is associated to?
Old 09-12-12, 04:04 PM
sc98LS400
sc98LS400's Avatar
my 1998 LS 400 has the same issue and i cannot find any other info myself, but.... when i pull the fuse my door locks,and my auto adjust tilt steering does not work......but the manual tilt works. i find this a little weird as we both have 98's and no info.
Old 08-24-14, 08:15 AM
JonBlaze2g
JonBlaze2g's Avatar
I'm havering the same issue mine is a 2000 my guess is there's a computer or relay that's associated and controls those things.
Old 08-24-14, 11:48 AM
offbad
offbad's Avatar
test your accessory electronics like power locks, windows, anything not mentioned specifically by the fuse diagram.
Old 04-06-15, 02:26 PM
BarryBrett
BarryBrett's Avatar
Default Fuse MPX-B Parasitic Draw
my 2007 ES350 keeps killing the battery. I measured the parasitic draw at 70 to 80 ma. Anybody know if this is normal? Online forums suggest 30 to 50 ma to be expected. The fuse under the hood in slot # 34 is a MPX-B 10 amp fuse labelled "meters" in the manual. It alone draws about 30 to 40 ma. What is on the "meters" curcuit?
Old 04-06-15, 05:56 PM
Mr Jokster
Mr Jokster's Avatar
I believe this is the Multiplex Communication System fuse. Unplug it and see what doesnt work, iirc it controls everything LoL like power windows, locks, radio lights etc. Its just a guess, but it may be a unit like body control module or something.
Old 05-07-19, 06:12 PM
fkallam
fkallam's Avatar
Default It powers a lot...
Your Vehicle: 2000 Lexus GS 300 L6-3.0L (2JZ-GE) Vehicle » Diagrams » Electrical Diagrams » Power and Ground Distribution » System Diagram » Power Source (Current Flow Chart)
See attached for my 2000 GS-300 same problem.
Old 05-08-19, 05:44 AM
TrueGS300
TrueGS300's Avatar
Shoot, even after finding the fuse for the system drawing amperage, you still have a lot of areas to check. That's a lot of stuff protected by that same fuse! My first suggestion is to go to all of your doors, seats, sunroof, etc. and make sure there are no switches jammed on. Activate everything and see that everything works and stops working when you stop pressing on a switch. Make sure the door switches are registering that the doors are closed. After basically switching everything you can, check again for amp draw. Maybe you will have unstuck the switch. Power seats and radios are a common amp draw from what I've seen.
Old 02-18-24, 11:38 PM
PinnySkenis
PinnySkenis's Avatar
Did you ever find a fix??
PinnySkenis
this was over 10 years ago so long shot but did you ever find out what was causing it??
Old 02-18-24, 11:39 PM
PinnySkenis
Ever figure it out?? I’m having the same problem.
Old 08-05-24, 04:08 PM
DhatLex
2nd gear
DhatLex's Avatar
BCM, but make sure it’s corresponds to your preface lift and facelift models. I’m having that issue and I just helped diagnose the issue for one of my friends
Old 08-05-24, 04:11 PM
PinnySkenis
whats BCM?
pentiumvi
RX - 4th Gen (2016-2022)
38
01-16-24 05:33 PM
ISFLexy
RX - 3rd Gen (2010-2015)
08-06-18 04:37 AM
BarryBrett
ES - 5th Gen (2007-2012)
04-06-15 02:53 PM
JohnnyCake
10-03-12 07:44 AM
spxChrome
07-10-06 04:54 PM
Quick Reply: MPX-B fuse
