Help with P1351 light
Trying to fix a 98 GS400 with a P1351 light that has been on since another person did the timing belt and cam seals. I have front of motor torn down to the timing belt and the timing marks all line up like they are supposed to. It looks like the four star bolts on passenger cam gear have been tampered with but are in the center of the adjustment range. Any help would be much appreciated as i dont have alot of experience with this motor.
It was in another state so that is not possible. I have done alot of research and am aware of the code but i am not clear on what it takes to fix it or diagnose it. I am very mechanically inclined so I just need to be pointed in the right direction.
put car all back together after cleaning ocv with brake clean and applying 12 volts to the valve and there is no codes, I will drive and make sure they do not return.
well, I drove the car for a while and the code came back. I erased it and drove some more and it came back, erased it and drove a little more. I am wondering if there is a good way to test the ocv to make sure that is the problem before I buy a new one. I applied 12 volts to the ocv while it was out of the car and it cycled, but is there a more in depth way to test it.
I ordered a new oil control valve (ocv) and replaced it tonight. I drove car a few miles and the code P1351 came back. I am in need of some help if anyone can shed some light on this subject.
