Has Anyone Tried This Mod? + 20 HP w/ a Resistor from Ebay
Master Thread Closer!!
Anyone tried this? Does it really work? I apologize in advance if this was a previous thread topic.
Here's an excerpt from an Ebay selling this mod:
LEXUS GS 300 GS400 Intake SensorMod Kit +20HP
ALL NEW
100% SAFE, 100% LEGAL!!
YOU WILL ALSO GET LIFE-TIME Guarantee, IF YOUR CHIP BURNS OUT, WE WILL REPLACE IT FOR FREE!!
LIMITED TIME ONLY, Buy It Now TODAY!
INTAKE SENSOR MODIFICATION
This is a modification to your Intake Air Temperature sensor that will let your engine breath cooler air and increase the amount of fuel that enters your engine. The increased air/fuel ratio that you recieve will bump up your horsepower significantly over stock cars with a resistor. Not only will you feel better acceleration and torque you will feel this through the entire RPM band.
Same Function as ECU Upgrades and Performance Chips Like the Jet V-Chip!
NO RESERVE! BID AWAY!
Give your Car or Truck up to 20 More HorsePower!!
We are the leading seller in modification kits for cars and trucks at the best prices possible!
This modification kit is for all models of your LEXUS GS 300 GS400
All parts are INCLUDED with easy to follow instuctions. This do-it-yourself kit takes no knowledge of cars and is extremely easy to install.
This mod tells your ECU that the air coming in through the intake is cold air this advances the timing 3-4º, therefore letting the engine produce more power. Releasing the true HORSEPOWER of your engine!
This mod is a fraction of the cost of those expensive ECU upgrades ($400+)
And does the same exact thing adds up to 20 HP!
Stop paying high prices for this MOD !!!
We buy in huge quantities, therefore giving you the best price on eBay!
DON'T BE FOOLED
This is the same kit, yes the same kit!!! that others are selling for much more!
This mod will fit all models of your car. It is extremely easy to install no tools are required and this mod will not damage your car in anyway. I have installed this myself in Less than 10 Minutes on my vehicle and it works, YES it does work!!
You will DEFINATELY notice the difference Right Off the Line.
It is More Responsive , More Powerfull & You will Like it!
Our Kit is one of the best!
Your car will accelerate faster and have a higher top end speed. This is a great mod for any car, and will definitely increase your HP up to 20 hp. Your 1/4 mile times will decrease a few tenths of a second or more and your 1/4 mile MPH will improve as well.
This mod is very easy to install anyone could do it. This mod is also just as easy to remove in 5 minutes or less and replace it if you want at a later time.
BUY IT NOW, PRICES WILL GO UP!!!
Easier & Faster than Pumping Gas
You will Not Be disappointed with the result.
This kit comes with a special EASY to READ Walk Through Instruction sheet.
If you have any questions please ask before bidding as all sales are final.
Take a look below at the most commonly asked Questions
If You have any further Questions feel free to email anytime.
* What year and model will this work on?It will work on ALL models (excluding turbos) from 1988 to present
Will This Void My Warranty ???
* NO This Will Not Void out Most Warranties. If you have a very strict Underwriter on your Warranty You can Undo this Mod in less than 5 minutes. You can even Re-Install later. This Leaves No Trace of Any Modification.
Will This Hurt My Car , Motor , Computer etc.???
* NO This will Not Hurt Your Car or Have any Negative effect on your Motor , Computer whatsoever. It is impossible to damage your engine by advance timing... In Fact This Mod will actually work WITH your car the way it is Designed. Use premium fuel for best results.
ALL NEW
DON'T BE FOOLED
Don't laugh too hard or too early....
The basic idea is sound.
If the ECU "thinks" the engine is getting more dense airflow than it actually is then it will increase the fuel/air mixture ratio. Now the oxygen sensor may "catch" the "discordance" and give the ecu feedback to correct the mixture, but maybe not fully. With that much advance the knock sensor might come into play but with a rich mixture that is less likely.
I certainly wouldn't ever run this "mod" with anything less than high octane fuel.
It would be interesting to know just how many degrees F the modification gives.
For myself I would be tempted to only have the resistor in the circuit at WOT, that way the oxygen sensor would not have already provided the feedback to correct the mixture and I would still get the extra HP for the short duration of WOT.
I would be tempted to try the inverse of this "mod" first, leaner mixture (rely on the knock sensor to protect the engine), and see if the MPG rating actually increases substantially.
XenonES3
12
11-02-02 11:49 AM
