Adjust transmission detent cable???
I have a hesitation when I take of from a complete stop causing the car to jerk if I apply to much gas.
I was reading on the 1st gen about the TPS and the transmission detent cable. I was wondering with having a 2nd gen if it is possible to adjust this detent cable to get rid of the rest of the hesitation? If so where can I find this cable to adjust
I had same problem with my accord and adjusting the throttle position cable on the tranny cured my issues
I adjusted the throttle cable to remove excess slack. And it def helped but not completely.
Fluid is the simplest place to start, and should be eliminated as a possibility before going on to other possible causes.
That was one of the first things I checked and it is at the correct level. And the color looks like its as new as it was 35k miles ago. I just ordered tranny fluid from Sewell yesterday. Those guys are great. I am not sure what intervals we are suppose to change it but my g35 was every 30k so that's why I am changing it even though it looks great.
Found a link that essentially does what the old detent cable did in the previous tranny. You will have to drop the pan to do it.
https://www.clublexus.com/forums/per...ting-dial.html
asadchinoy
02-18-07 05:47 AM
