Rear light icon on instrument panel
I have an 02 gs300 with a rear spoiler. As I was taking off this morning to go to work I noticed an icon light up on my instrument panel and it was the little car with the rear lights. When I got to work I had a co worker step on my brakes to see which of the lights were out and all the brake lights worked but the LED's on my spoiler had a few out could this be causing that light on my instrument panel to illuminate? Also checked my turn signals and reverse lights an they are working.
OP someplace you do have a brake light out, since i dont have a spoiler i dunno if the LED's out on it will cause that light or not but one of your lights is def out. have someone step on brakes AGAIN and check them closely....i swore up and down all mine worked but eventually i did find one that was out. i replaced it and it went away....
its not a fuse....if it was a fuse his lights wouldnt work period
op someplace you do have a brake light out, since i dont have a spoiler i dunno if the led's out on it will cause that light or not but one of your lights is def out. Have someone step on brakes again and check them closely....i swore up and down all mine worked but eventually i did find one that was out. I replaced it and it went away....
Yes could be the lights going out on your spoiler that is giving the code.. I had the same problem but since i didnt have a spoiler the problem was on my 3rd brake light where one of the led lights were out. Get it replaced and it should fix your problem
well yours was different if his lights light up at all as he said they do its NOT a fuse
before you do this look over the other lights i really think you have another one out, i dont think the LED's on the spoiler affect this, i told you i had a tricky one for a few days i couldnt find it but then i finally noticed it
i dont recall 100% but im fairly certain the city lights wont affect this bulb
he doesnt have a rear deck light, as he stated, he has a spoiler so he wouldn't have a 3rd deck light
oh well, i won't have to worry about it since i did the mod to cut the light out.
Slow_go_400
SC- 1st Gen (1992-2000)
01-30-02 11:09 AM
