question for 14yr old gs4
I have a 98 gs4 with over 255k miles on it. Just curious if i should use only oem parts or are aftermarket parts ok? I need a new MAF sensor, waterpump, and fix the front suspension. My steering wheel shakes around 50-60mph.
THere are some good aftermarket brands out there that are just as good as OEM... Moog and others offered on ebay are pretty well made from what i've heard. With the mileage at 255K you probably don't want to put a bunch of money into it the car when the same parts can be had for half price from good companies.
If you feel more comfortable with OEM then check out our Vendor Sewell... Good prices and we get a CL discount..
http://lexus.sewellparts.com/parts-c...S400-1999.html
www.rockauto.com for all your needs on the cheap from good brands.
I would actually buy aftermarket suspension parts and get original timing belt components/water pump and maf sensor. As said before Moog is good and you can get Aisin (OEM) timing belt kit at RockAuto.
what brands have the best ratio quality to price for:
-suspension
-waterpump
-maf sensor
-timing belt
-serpentine belt
on rockauto?
i dont know much about these brands. just looking for something that wont need replacing after a year.
thanks in advance
-suspension
-waterpump
-maf sensor
-timing belt
-serpentine belt
on rockauto?
thanks in advance
-suspension - Do you know what needs to be replace?
-waterpump - Buy OEM
-maf sensor - Get a use one in the GS classifieds forums
-timing belt - Buy OEM
-serpentine belt - Buy OEM
http://www.sewellparts.com
(sign up using your CL ID than your discount shows)
http://www.l-tunedparts.com
Phone number: 800-908-6968
(I find it easir and sometime you get better deal just calling directly)
www.rockauto.com
(is a good place for suspension parts too but got to know what you need first)
www.rockauto.com
EPayne42
12-23-14 11:54 AM
