what should i do next ??
ive had the car for 3 months and went through headaches with the limp mode b.s.
after finally just swapping out the throttle body everything went back to normal.
after that i replaced and purchased
- sway bar links
-lower control arm bushings
-sway bar bushings
-upper control arms
-drilled/slotted rotors
-upper strut mounts
-brake hardware kit ----solved my thumping noise $10 fix
-2 tanabe mufflers (powder coated black)
-obx headers with 3 inch piping
-short air intake'
-window visors
-roof wing - 3 piece trunk wing (not installed)
-6k hids on lows and fogs
....my next step would be coilovers and a set of wheels for the summer
any suggestions on what wheels i should go with i want a staggered look
- sway bar links
-sway bar bushings
-upper control arms
-upper strut mounts
-short air intake'
-window visors
The wheels Easton gets are from Japan. He either finds an aggressive set to refinish or finds a weak set to rebuild. Ive looked around for almost a year now and czwheels or vrmotoring are good companies, which essentially do the same thing.
I mean you have to pay to play and they got pretty good deals imo. The next best bet is to look around classified forums like vsc, clubrsx, or zilvia and hope u get lucky.
yea wheels arnt cheap.. least good wheels arnt cheap. Same applies for tires. good tires arnt cheap and cheap tires arnt good.
are those OEM rain visors? if not get some Toyota ones in place of weathertechs.
Then get coils and roll on stock wheels till you gather enough funds for some proper wheels.
