Need help with stance coils..
Old 01-20-12, 05:21 PM
Lexustrung
Lexustrung's Avatar
Default Need help with stance coils..
Is there anyway to adjust ride height of coils without taking everything out. I just installed and need to raise fronts. Keeps rubbing don't wanna take it all off just to raise it..
Old 01-20-12, 05:36 PM
LudeNsoL
LudeNsoL's Avatar
A way I did it was just unbolt it from the top (strut tower) and let the suspension fall down then you should have enough room to twist it up to raise the car. That the easiest way for me if your only raising it a bit.
Old 01-20-12, 05:38 PM
L3XOTIC
L3XOTIC's Avatar
Mind posting some pics for us to see how low you went?
Old 01-20-12, 05:45 PM
Lexustrung
Lexustrung's Avatar
Thanks I'll try that right now.. Also how would i adjust dampening so ride is less bumpy? All the way to the right or left? Cause I took a test drive and it was really bumpy and a lot of rubbing in front. Will post pics when I can
Old 01-20-12, 05:52 PM
Lextasy671
Lextasy671's Avatar
im dropped on stance coils..love them. rides great. just adjust em the right way..take out those bottom bolts. hahaha...anyway, soft if counter clockwise. if im not mistaken, you ride them on soft for a few days..then adjust there on. i have mine on 8 clicks.
Old 01-20-12, 06:31 PM
808_GS400
808_GS400's Avatar
you dont need to remove the suspension to make adjustments. refer to the link. its for Megan coild but it should be similar what you have:
http://www.meganracing.com/tech/inst...5&subject=CDK: How to properly adjust ride height after spring pre-load has been set
Old 01-21-12, 01:17 PM
Lexustrung
Lexustrung's Avatar
here are pics with stance coils on, i think i need to go lower in front? what do you guys think?
Old 01-21-12, 03:13 PM
Redline26
Redline26's Avatar
Yeah i dont think he was talkin about removing the whole suspension. Just a way to adjust the coils without takin off the tires.
Old 01-21-12, 03:14 PM
Redline26
Redline26's Avatar
Imo either lower the front or raise the rear a bit to have a more staggered look.. it also depends how comfortable u want the ride
Old 01-21-12, 09:28 PM
Munchiez
Munchiez's Avatar
To trung it's David. When are you putting the new wheels on?? Looks good btw
Old 01-21-12, 11:47 PM
abounly
abounly's Avatar
Loosen the collar which adjust the height and turn the BODY of the coilover thats it. No need to take off any bolts or loosen em
Old 01-22-12, 10:47 AM
Lexustrung
Lexustrung's Avatar
Yea that's what I figured out when doing some thinking haha. Thanks bro.
Old 01-22-12, 10:56 AM
puff
puff's Avatar
Drop looks good.
Old 01-22-12, 06:59 PM
Acer
Acer's Avatar
Any wheels coming in?post pics.What type of suspension you have?
Old 01-23-12, 08:24 AM
justablkv8
justablkv8's Avatar
Yea, as stated earlier -- you adjust coilover height from the lower perch first i.e. the body.
Thats the correct way of doing it.
Quick Reply: Need help with stance coils..
