Torn door edge molding that's along the bottom of the front doors... FIXED!
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
This has annoyed the @$#E@ out of me for 2 years now, but I finally found a product that works.
Before this, I tried tape, crazy glue, 3M glue, etc.
Anyways, its called-Plastic Welding System, I bought it at Napa.
Comes with 2 tubes of glue, mix the ingredients together and apply to the inside (the unpainted part of the trip, inside part of the door). After it dried, I used a razor blade to trim the extra glue and made everything look neat.
I figure this should hold for a few years, unless a passenger opens the door and the bottom scrapes against the curb.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Great timing! The piece you're talking about (I think) on mine just ripped into a much larger gap from the small previous tear.
Couple of questions:
1) Is this the piece you fixed? Just want to confirm..
2) Is the stuff you bought black, clear or some other color?
Forum Administrator
The (now) big rip. Bums me out.
DaveGS4-No, that's not the peice that I am talking about. I'm talking about the part that is ON the door itself. Its on the bottom of the door.
But you're lucky, your part can be easily replaced and its cheap too.
acnup00tl- I was about to replace it but since my car is pearl white, over time, the bottom of my car faded and is yellowing, just a little. If I replaced just that molding on one door, the color would not match with the rest of the car, it would stick out like a sore thumb. When I thought about replacing all the moldings, that would add up to over $300 so it wasn't an option either. Luckily, I found the cure. I recommend that anyone with the smallest tear, to fix it early before it spreads.
i know i'm bring this back from the past, but can anyone advise of a part number or what this part is called. i may try use the above mentioned glue to try to fix it, but i also want to keep this open as an option. thanks.
http://lexus.sewellparts.com/oem-cat...S430-2001.html
so try this guy,darrel should be able to help you find whatever your looking for
https://www.clublexus.com/forums/mem...99-sewell.html
i was going by dave's picture and skimming since im fairly busy today at work and no real time to be on here but after actually re-reading, you were right...
to me.... see this is where i wish these posts either got deleted or merged with threads like the one you link to keep down confusion
adidosc
SC- 1st Gen (1992-2000)
12
06-24-03 05:12 AM
