Help! 1999 gs400 fuse diagram
i was wondering if someone could help me out, i just bought a gs400 and the radio and clock fuse went out, the covers are missing that tell you which fuse is what, i was wondering if someone could take a picture of theres both driver side and passenger interior for me. thanks
*Also a second question, the car seems to have a drain from the battery if it sits I was wondering how do I go about findin what is draining the battery. thanks guys
On our cars, battery drain shouldnt be anymore than 70 mA. Get a DVOM, set to mA, disconnect negative cable, connect the meter in series with the negative cable and check the reading. If its higher than 70 mA, start disconnecting fuses see if the amp reading goes down. Before you do this test, you must make sure ur door is closed, all lights are off and key out.
since you have a gs400, theres a fuse that blows and it causes a surge in the fuse box even when the car is off, so it steadily drains battery even if your vehicle is turned off
Ickey
32
09-08-20 09:18 AM
mb12345
03-09-11 07:22 AM
illimental
12-30-05 12:11 AM
