Taillights out but brake lights work? Help
I searched about this info and couldnt find a definative answer and was hopin maybe you culd help me here. I just got this car sunday and I am almost positive the taillights worked then. They are the LED lamps with the white stripe ont he bottom. I dont have the fuse covers to tell me what fuse is what but the other day a very nice member took some pics of the drivers side and engine fuses for me. i checked the one that said TAIL and it had a 15amp fuse when im pretty sure its suppose to be 10 (his was a gs430 but the diagram should be the same for a gs400) and it wasnt blown but i put the proper 10a in there. the weird thing about this is, the brake lights work, the turn signals work its just the taillights dont (when you turn your headlights on they shopuld illuminate) and i dont have the stock tails to test them. Sooo, what do you guys think it is? Maybe a relay and wheres that located. Any help would be great
its all of them, im not %100 certain but I think the lisence plate light is out too. I dont remember seeing any lights on back there last night. however the turn signals and brake lights illuminate fine.
ok ill have to check that, they were installed by the previous owner. where would these resistors be at, at the fuse box or back by the taillights. and the brake lights work its just the taillights dont, the light that comes on when you turn your headlights on is whats not working. the turn signals and when i apply the brake work. rather frustrating lol
So your parking brakes don't work. Have you checked all connections? The connections on the LED tail lights can some times become loose. You'll have to go to the direct connection into the light and see if they are snug. I had a problem with mine and I pushed them back in tight and they all worked again.
ok thanks shvc1991, ill give that a try tomorow. I did notice my taillamp indicator on the dash is on as well indicating they are out, ill give that a go tomorow and let you know if it works
i just checked my connections and there tight and evrything but they still wont work. i checed the relay(switched it with the same sized fog relay) still nothing. Any other ideas?
getting a test light in a bit, how do i use that for the tail lights?
also i just got the layout of the drivers side fuse box and i removed a wire from TAIL to SRS-ACC. it was a little speaker wire that the previous owner jump from the tail fuse to the SRS-ACC fuse. im going to put it back in and see if that works but what would be the reasoning behind that?
extremely weird! I just put that little wire back on it. like a little jumper wire back from the tail fuse to the srs acc fuse and the tail lights work? whats up with that? what is srs acc anyways. i i take that wire out the tails dont work. if you need a picture of what i mean let me know i hope im explaining this right?
Peter_95
SC- 1st Gen (1992-2000)
17
10-16-10 09:42 AM
Flex33
06-27-08 06:56 PM
