Stupid question, Where is the blower motor fuse/relay for 99 gs4?
looking for the blower motor fuse or relay for a 99 gs4 . i took the blower motor out and it seems to jump but not stay on. i wanted to check the fuse but no clue where its at,
Thanks sam Ill check it out today.
The blower motor isnt working. i dropped the motor and tested its good, tested 6 volts at the power plug for blower motor. i was thinkin maybe fuse or relay. Hopefully I can ffind the problem.
Koedpa (04-01-24)
something else that is weird is the motor wont turn at all on the fan but when i turn the key to off its like it gets a surge of power and moves for a split second..... anyone can help me?
Behind glove box behind cd player behind blue plug way in the back against firewall to the right of center stack. Make sure you test the obvious stuff first cuz you got to do some unscrewing to get to that. Also search ac diagnostics you can run by pressing a sequence of buttons on your climate control.
thanks sam, i just replaced the relay to no avail, i tested power at the blower motor plug to 5.1 volts which isnt enought to spin the fan, the blwer otor works, new relay didnt help, do you think it is the blower control? or is there any other fuses or relays i should check? hope someone can help me
well in my case it was the ecm but I had 25 things not working correctly among the blower motor. It does seem suspicious because of the voltage at the plug. Do a search and see what other people had at the blower plug. Most had the speeds not work (always on high speed) before complete failure of the blower control. Worse case you can get to the blower controler and do the test per the manual. Also check all the connections and spray some contact spray. You never know may be a bad contact on one of the connectors. If you don't want to take her apart you can always find a shop with a scanner.
Where is the ECM located at for the blower motor? I was unsure per the service manual, I bought anew blower motor control and it didnt work, so Im going back to the wiring and double checking. Could it be the LCD climate control? it works as you can go up and down through fan speeds but just not turning the blower on. i find it weird about the volts, others said the volts decreased when they decreased speed of fan however mine stays pretty steady at 5.1, it may be the ecm because my blower doesnt work, my windows always have power to them and i have a parastitic draw somewhere
Not blower ECM the ECM (engine control module) I doubt that is your problem unless you have multiple problems. The ECM is in a box under the hood behind driver side headlight. I think if I was you I would go to a shop that has a multiplex scanner. I would tell you to go to Lexus dealer but you will get raped there. You need to go to a guy you can trust. I have a climate
Control unit ( non navigation) if you pay for the shipping and it fixes it I'll sell it to you for 150.00 if it does not fix the problem then ship it back at your expense. So all you would loosenis the shipping if it is not the climate
Control unit. I also have both body. Control modules. I also am selling them in the classifieds. Did you do the climate
Contol diagnostics? It's in the stickies. Also check that your grounds are good. It could even be a weak battery.
