spacers issue.....is this safe?
im trying to fit a set of 15mm spacers with built-in studs on my front wheels but the pockets on the back of my wheels are not deep enough for my factory studs to go into, therefore the wheels dont sit flat against the spacers
Would it be safe if i cut off the tip of the studs, the part where its not threaded? without those, it should fit in the wheel pockets just fine. I just want to get opinions from others before i make a move on it. Thanks
If you do not have a thread chaser, use an open ended lugnut, then thread the chaser or nut all the way down the wheel stud, then trim the tips. After you remove the tips, remove the chaser or nut. This will help just in case you happen to cut into the threads of the stud, and straighten them out. Sometimes, when you trim studs, the threads can get messed up, and the end result is a cross threaded lugnut and then a broken wheel stud.
