Anyone with spacer knowledge..
Im a noob here...and if theres a thread all about spacers direct me to one....my question is how many mm do I need so flush tire to fender..thanks
If all four wheels are the same and the rear just looks a bit sunken you would probably need about 10-12mm spacer in the rear. since that isn't enough to be able to get bolt on spacers you will probably have to get some extended wheel studs before using slip on spacers. this is what I'm doing to my car to even it out. I'm running IS300 ARP extended studs and Novustech 10mm hub centric slip on spacers.
If the wheels rub you'll need to get a fender roller or use some other rolling technique like baseball bat or pipe method like I usually do.
yea my bad on not giving the complete wheel specs...well im sitting on 19x95 +23 front 19x11 +24 rear....225/35/19 front 255/35/19 rear...im looking into getting the spacers already with the extended studs ...
Master Thread Closer!!
do you mean flushing wheel lip to fender?
if so, seems like your already beyond flush (assuming no modification to fenders)...why the need for spacers?
i never heard anyone flushing tires to fenders...lol.
phml....no right now im wheel lip to fender but im tucked fender over laps rim and tire...i want the fender to barley sit on some tire so I can roll fenders a bit more get me?
