front sway bar bushing noise
Old 02-06-12, 06:14 PM
LexXxuS101
LexXxuS101's Avatar
Unhappy front sway bar bushing noise
How often do you guys change sway bar bushing? for past couple months i'm experiencing lots of noises/rattle/clunk sound coming out of the front, especially when i'm going over small potholes/speed bumps. last night i sprayed WD40 on front sway bar bushing and replaced sway bar links and noise went away BUT that over speed bumps/potholes clunking noise still present, so i am guessing i need new bushing? its just aprx. 30,000miles ago i replaced oem ruber bushings with new daizen polyurethane bush. and now after 30k miles again? aren't they supposed last long? ........2day ordered new daizen bushing set.
Old 02-06-12, 07:01 PM
PHML
Master Thread Closer!!
PHML's Avatar
lithium grease...use that.
Old 02-06-12, 07:46 PM
Navaz
Navaz's Avatar
Check the sway bar mount. Make sure it us still tight to the frame. It could also be you lower control arms.
Old 02-06-12, 07:47 PM
Navaz
Navaz's Avatar
Check the sway bar mount. Make sure it is still tight to the frame. It could also be you lower control arms.
Old 02-06-12, 10:26 PM
YviE
YviE's Avatar
Silicone grease is your best bet. Lithium grease will attack the rubber/polyurethane.
Old 02-06-12, 10:28 PM
YviE
YviE's Avatar
Daizen bushings (like all polyurethane bushings) are supposed to last a very long time.
Old 02-08-12, 08:53 PM
850Lexus
850Lexus's Avatar
I am having similar problems and I have replaced everything but the uca, sway bar bushings, wheel bearings, and inner tie rods.
Old 02-08-12, 11:33 PM
randee973
randee973's Avatar
I had a similar problem replaced my rotors pads noise reduced - but stil heard a small rattle going over bumps so I swapped out the sway bar bushings and walaaaa problem solved
Old 02-09-12, 05:42 AM
sam12345
sam12345's Avatar
Have you changed your ball joints?
Old 02-09-12, 08:13 PM
GS714
GS714's Avatar
Default what did you swapped out with?
what did you swapped out with? Regular rubber bushing for polyurathaine bushing?
Old 02-11-12, 08:24 AM
GS714
GS714's Avatar
Default What about your Lower Ball Joint
You replaced the sway bar bushing with the polyHoly Bushing. what about the Lower ball joint? Is it still OEM or Daizen or Sewell/Carson bushing polyurethane bushing as well.
Old 11-19-12, 11:00 AM
BayAreaLex
BayAreaLex's Avatar
I'm wondering if you noticed anything obviously wrong with your old bushings when you replaced them?
I ask because I've been noticing a similar problem in my 2001 GS430 of minor clunking going over rough surfaces at low speed. I replaced the end-links this weekend.
When I looked at the sway bar bushings, they looked fine, and so I avoided replacing them, but now you got me wondering...
norviewguy
03-08-18 04:21 PM
acarapella
12-12-17 12:27 PM
HammerDown
Suspension and Brakes
01-30-15 07:09 PM
One HoT
SC- 1st Gen (1992-2000)
06-25-03 11:20 PM
Quick Reply: front sway bar bushing noise
