Gas cap
Old 02-09-12, 02:33 PM
XavierGS3
XavierGS3's Avatar
Default Gas cap
I took my car to get serviced the other day and the mechanic said I should get a new gas cap. My check engine light was on, and he says that it may have something to do with that. Also, I noticed my car burning gas faster than normal. Any thought in Club Lexus land???
Old 02-09-12, 02:36 PM
GS4_Fiend
GS4_Fiend's Avatar
Gas cap is cheap. $10. If ur engine light is on retrieve the code dont play guessing game
Old 02-09-12, 02:39 PM
XavierGS3
XavierGS3's Avatar
Well, the mechanic said I do need a gas cap from when he got the code. It was hard to understand him as his English was not very good. I'll try another guy to give me the code and see what his opinion is. Thanks for the reply.
Old 02-09-12, 02:54 PM
Debonair
iModerate
Debonair's Avatar
You probably have a code indicating an EVAP leak. The gas cap being on loose or leaking is a pretty common cause for this. He may have actually tested it for you or just be assuming its the cause. If you have an aftermarket locking type that may be why he is making the assumption since these tend to fail and cause this issue.
If he is guessing he may be wrong but a gas cap is a pretty cheap fix to try.
Old 02-09-12, 02:57 PM
L3XOTIC
L3XOTIC's Avatar
Get a gas cap if he says thats what the code is for. Sometimes CEL codes link into multiple things and you have to start somewhere...
Old 02-09-12, 03:02 PM
GS4_Fiend
GS4_Fiend's Avatar
Im surprised people actually forget to tighten the gas cap after refueling. Just cant believe it
Old 02-10-12, 06:19 PM
lexusben
lexusben's Avatar
You know what's weird? I want to the dealer about a month ago and when I got my car back I too had a check engine light and they said I needed a new gas cap. I still need to go out and get one I've just been feeling lazy.
Bluv
09-30-22 10:15 PM
MellonC00
RX - 1st Gen (1999-2003)
06-24-20 11:51 AM
awesomefar
06-12-18 06:33 AM
onexcite
07-17-12 06:41 PM
TruPlaya26
06-16-12 11:08 PM
Quick Reply: Gas cap
