GS high beam bulbs
Old 10-24-02, 11:16 AM
RocketSlug
RocketSlug's Avatar
JCWhitney baby! 100w (instead of 65) replacements for about $11 each. Adding blue or purple (or worse) filters to the bulb glass to make them appear white has no true benefit to the human eye. . .we are least sensitive to the blue light spectrum and this actually causes more glare.
The 100w full spectrum (regular) halogens light up signs for over 1/2 mile, when I get an opportunity to use them. I use them more to flash people into traffic or to pass, and with that much power, you can see them in daylight.
Old 10-24-02, 11:37 AM
MrSypher
MrSypher's Avatar
RocketSlug, becareful not to fry your wire harnesses.. Did you upgrade your wires when you put in your 100W bulbs?? The OEm wires aren't meant to to pull that much wattage through them. A few years ago I did the same thing and I ended up frying my wires..
Old 10-24-02, 11:45 AM
///MDex
///MDex's Avatar
Originally posted by RocketSlug
JCWhitney baby! 100w (instead of 65) replacements for about $11 each....
I bet the PIAAs, albeit more expensive initially, are just as bright if not brighter, and won't melt anything; they're still 55W.
Just a thought.
Old 10-24-02, 06:51 PM
RocketSlug
RocketSlug's Avatar
What bulbs were you using? How long were you running the things? And at what ambient temperatures? I would always run them for a few minutes after going to the drag strip (which is in a rural area) and even a few minutes in town, and I was suprised how cool everything was. . .I expected everything from the lens back to be hot, and it was not. Plus, I'm only going over by 35watts, which isn't too aggressive.
I honestly can't run them as long as I would like. . .they reach at least a half mile or more, and the HIDs cover almost every other situation. They are more for justice distribution than anything else, especially against people who won't dim their bulbs in downtown traffic.
I don't know how bulbs, at least ones using halogen gas, can be "brighter" and pull less wattage. They may appear "whiter" and therefore "brighter" (due to visible spectrum filters) but I would think it is impossible for a lower wattage *halogen* bulb to put out more lumens.
If someone has the box to one of these low-watt megabuck boyracer blue bulbs, please post the lumens and I will compare them to my full spectrum 100w. Blue/purple is a byproduct (or throw-away light) produced by the arc in the HID process. Tinting, shading, and reducing the output to gain a color or look is not advantageous.
So why don't I go with HID to replace my brights? Respone time. Flashing HIDs is like flashing a office building fluorescent light at people. It just doesn't work like halogen.
Old 10-24-02, 09:24 PM
Kash
Kash's Avatar
no but driveing behind them with your xenon high beam bulbs will sure let them know your pissed offf
Old 10-25-02, 09:08 AM
bagwell
bagwell's Avatar
go with RAZO !!! color is perfect match for XENON...
koreanguy9
10-19-14 06:43 AM
Megafast13
Lighting
11-17-09 09:32 AM
mikeloc24
SC400 / 300 Classifieds
32
04-01-05 01:06 PM
lexusnexus
Lighting
07-20-03 06:34 PM
Orias
SC- 1st Gen (1992-2000)
15
05-06-02 02:28 AM
Quick Reply: GS high beam bulbs
