ordered my balljoints ! n guess what happened !
Old 02-19-12, 10:01 PM
GS714
GS714's Avatar
Default Where is the tension rods located?
Originally Posted by NtnsOliver
I did the tie rod ends, lbj's, and the tension rods all in one shot
Did you meant the trailing/caster arm? See the link below. Please point me to it. I am having the timing belt done tomorrow and will ask the mechanic to take a look.
https://www.clublexus.com/forums/sus...s-of-pics.html
Old 02-20-12, 01:29 AM
AKVIPGS3
AKVIPGS3's Avatar
My passenger Balljoint just failed on me last week too... i said im gonna replace it when my tax refund comes in and Boom! it happened... sadly i knew that i should've replaced it sooner... its got 190k miles...
Old 02-20-12, 05:09 AM
SaiyanGS3
SaiyanGS3's Avatar
At that mileage, you really can't complain. Sad that happened, but you knew you were rolling dices every time you drove your car, especially with all of the threads on this site.
Old 02-20-12, 06:33 AM
repugnante
repugnante's Avatar
Man I hate to read threads like these....
Glad no one was hurt...other than your wallet of course.
Old 02-20-12, 06:34 AM
iRyan
iRyan's Avatar
Ouch man...I know that must be frustrating...but I'm glad it was nothing too too serious...no injuries
Old 02-20-12, 09:35 AM
islexusred
islexusred's Avatar
I had the same thing happened to me last week but luckly i was reversing form my drive way. it cost me about
400 bucks to replace them both. ans some how my ABS/VSC light came on and the dealer told me it got streched when the LJB gave out. another $400 . hope yours is fine
Old 02-20-12, 09:51 AM
jadu
live.love.laugh.lexus
jadu's Avatar
ironic aint it.. glad your alright
Old 02-20-12, 10:02 AM
NtnsOliver
NtnsOliver's Avatar
Yes castor arm, sorry I come from a 240sx background and to me that arm is called a tension rod
Old 02-20-12, 10:06 AM
NtnsOliver
NtnsOliver's Avatar
This is easily fixed, by soldering new wires in. No sense in replacing the sensor if it was just the harness that went out. Same thing happened to me, luckily my brother had a ton of wiring left over from when he stripped down his drift car.
Old 02-20-12, 01:34 PM
GS714
GS714's Avatar
Default Passanger side's caster arm failed
I don't think the right caster/trailing arm failure is/was a coincidence. My co-worker who has a 2002 GS, his caster arm was replaced cause it was cracked. I am having a very very minor vibration when doing 80mph coming from the right front end at well. The mechanic suspecting it could be either the Tie Rod or the Trailing/Caster arm.
Old 02-20-12, 03:57 PM
randee973
randee973's Avatar
i replaced tie rods . uca lbj lca and links ... everything on both sides ... EFF it. now i need a fender
Old 02-20-12, 04:54 PM
Kzoosho
Kzoosho's Avatar
Been there with mine.
Old 02-20-12, 04:56 PM
MrG4Life
MrG4Life's Avatar
Sucks to hear OP but glad you are okay. Although it appears that the 98-00 GS' seem to be the years with the LBJ issue, I have set of OEM LBJ's in the garage that need to be installed. I just have to order my FIGS parts so I can replace the parts at the same time.
Old 02-21-12, 05:56 PM
chubz
chubz's Avatar
damn this is scary. could have been worse. i think im gonna take mine to get checked out to be on the safe side.
Old 02-21-12, 06:08 PM
99 GS3
99 GS3's Avatar
Caster arm, radius arm, tension rod, they get used interchangeably doesn't really matter it is just describing the arm that locates a lower control arm that is not a wishbone/a-arm type.
Quick Reply: ordered my balljoints ! n guess what happened !
