Tire rubbing
Old 02-27-12, 01:37 PM
vwynn
vwynn's Avatar
first off.. i dont get why people think the tires are to tall.. its well within the OD of the OE tire size.
and to the OP. shave the fenders.
Old 02-27-12, 02:39 PM
gs400rpg
gs400rpg's Avatar
Then why does it rub?
Old 02-27-12, 03:18 PM
vwynn
vwynn's Avatar
because his Rim + Tire combo = rubbage.
Shaving the fenders should fix it since it doesnt look like its way to aggressive at all.
theres so many people on this board that thinks getting smaller profile will cure everything bit it doesnt because now your speedo is off. Theres a reason why Toyota/Lexus have a recommended size. and theres a reason why tire shops can only recommond tires of the same OD +/- 3%..
Old 02-27-12, 05:25 PM
LexiBlue
LexiBlue's Avatar
lower profile tires u should be fine
Old 02-27-12, 06:39 PM
TTurboPimp
TTurboPimp's Avatar
I cant believe there have been this many replies and only 1 person mentioned offsets of the wheels. Those tires would fit fine with the proper offset wheels.
At this point you have them, so try shaving the rear, its easy to do. Just read up on it by using the search button to educate yourself on the proper way to do it. If that doesnt work, look into the offests of the wheels bro. You can change every other factor to try to compensate for improper offsets. Not saying yours are since you didnt mention what they were, but I would bet that they are not ideal.
good luck.
Old 02-28-12, 05:48 AM
Hardrvin
Hardrvin's Avatar
^ Hey now, 3 of us have asked about offset.
I'm guessing the OP doesn't know what "offset" is as he never replied to my question asking the offset of those rims.
Unfortunately "reverse spacers" don't exist to correct this type of issue.
Old 02-28-12, 06:42 AM
enigma65
enigma65's Avatar
The offset is HPO I'm not sure the actual # however I'm just getting into the staggered thing so its a work in progress!!!
93 GS 300 working
02 E320 daily driver
98 EXPO wkend fun
Old 02-28-12, 09:58 AM
Hardrvin
Hardrvin's Avatar
Read up on offset so you understand what you're getting into, and thus proper wheel fitment. It's an extremely important detail. Rim width only gives you half of the story of what will and won't fit.
http://www.1010tires.com/tech.asp?type=wheels
Also a link to a calculator to figure out what happens w/ different rim widths and what off set you'll need.
Width and offset go hand and hand. To maintain the same fit, you'll have to mess w/ the offset.
And as I eluded earlier, spacers will only shift your offset one direction. Obviously you can't suck a wheel inward.
Old 02-28-12, 10:26 AM
vwynn
vwynn's Avatar
now everyone above mentions offset lol.
well heres the thing about it.. its kinda too late to mention it anymore since the only thing you can do is add spacers to change offset.. hes already rubbing on the fender (or at least thats what it appears to be doing) so changing up the offset via spacers wont do any good.
if the OP wants to keep the rims.. he wold have to do some fender work or get a narrower tire or add negative camber.
a combination would work IMO
also stiffening up the suspension would help too haha..
Old 02-28-12, 11:59 AM
Hardrvin
Hardrvin's Avatar
^ I asked about it but didn't provide more input (kind of a smart A about it).
Granted the pictures gave us some input, but we're all suggesting camber, shaving, etc and depending on the offset of those wheels, it may not be enough still.
Also thinking that if it does come down to having to switch wheels, he'll have more information to use next time he selects rims.
kams229
07-09-12 05:30 AM
m32
VIP Style
12
04-13-12 12:02 PM
poorbong
IS F (2008-2014)
12
07-22-11 10:43 PM
spotxc
10-12-09 08:33 AM
alwayzspeedin
04-19-09 03:31 AM
Quick Reply: Tire rubbing
