infiniti M35/45 projector retrofit
Old 02-21-12, 09:08 PM
monkey92
monkey92's Avatar
Default infiniti M35/45 projector retrofit
Been wanting better light output on my car, so i finally saved up and got some infiniti M35 projectors from TRS to do a retrofit. To make things easy i ordered the brackets from tony at luxurymods, thanks tony for helping out with all the questions, this is my very first ever retrofit so im still trying to play with the cutoff line and doing some color mods. now on to the pics of the progress so far.
Attached Thumbnails infiniti M35/45 projector retrofit-2011-11-03-17.04.11.jpg   infiniti M35/45 projector retrofit-2012-02-19-00.58.17.jpg   infiniti M35/45 projector retrofit-2012-02-19-00.58.38.jpg   infiniti M35/45 projector retrofit-2012-02-12-21.33.29.jpg   infiniti M35/45 projector retrofit-2012-02-21-13.55.47.jpg
Old 02-21-12, 09:31 PM
justjosh
justjosh's Avatar
How hard was it to remove the lens?
Old 02-21-12, 09:35 PM
Kyle Harty
Kyle Harty's Avatar
It's not hard, just take your time and use an oven at about 200 degrees or a heat gun. I always start prying from the outside corner and work towards the high beam section.
Old 02-21-12, 09:36 PM
monkey92
monkey92's Avatar
its not hard at all, after removing three screws that holds on to the shroud and take it off, you take off two more screws on a brackets like thing that holds on to the lens and there it is.
Old 02-21-12, 09:37 PM
monkey92
monkey92's Avatar
what a min, did you mean the len of the headlight or the lens from the projectors?
Old 02-21-12, 09:43 PM
justjosh
justjosh's Avatar
Lens off the headlight lol. I have done a few retrofits before and the last one I did was the biggest pita to get the lens off. Thinking about doing a retrofit on my GS but only if the lens is easy to take off lol.
Old 02-21-12, 09:50 PM
abounly
abounly's Avatar
Its easy to take off, just make sure you have something to cut the stretching glue cause ones its on your housing it wont come off.
Old 02-21-12, 10:45 PM
kowala
kowala's Avatar
x2 making sure you don't get glue on the lens is definitely one of the scariest parts, i'm still in the process of doing my retro because of that reason, had to order a new headlight just to use the chrome shroud. once you have the lens apart it's pretty simple from there.
Tony at LM, is definitely the man!! he helped me along the way as well.. props to him. definitely a cool guy to deal with.
OP: can't wait to see pics of it finished.. that cut off definitely looks sharper than the q45.
Old 02-22-12, 01:49 AM
Lextasy671
Lextasy671's Avatar
another retrofit build. i should start saving to do mine. how much did everything cost you?
Old 02-22-12, 07:53 AM
monkey92
monkey92's Avatar
sorry i thought you meant the projector lens since i did a clear lens swap lol, i actually have never taken the headlights lens apart so i do not know, but i will be trying it for the first time today when i get off school.
coming from this now i will def. have to be real careful trying to take it off today. i will take more pics along the way and hopefully i will get close to finishing today.
the parts im using put me at around $400.
Old 02-22-12, 08:05 AM
LuxuryGS3
LuxuryGS3's Avatar
Can't wait to see it done Carlos.
Old 02-22-12, 08:34 AM
monkey92
monkey92's Avatar
ill shoot you some pics of the progress today if i finish ahah
Old 02-22-12, 08:46 AM
21SF
21SF's Avatar
I just did one for about 400. Make sure you plan everything out so you only have to open your lights once.
If your lights arent in very good shape, to the point where you are happy with them before your retro then just buy new ones.
thats what girlfirends are for
Old 02-22-12, 10:09 AM
LuxuryGS3
LuxuryGS3's Avatar
Already bro! I can't wait to see the output.
Old 02-22-12, 03:20 PM
abounly
abounly's Avatar
https://www.clublexus.com/forums/gs-...retrofits.html
Here you go,
Quick Reply: infiniti M35/45 projector retrofit
