Found a GS300, but now I need advice... (oil leak) *pic*
Old 02-26-12, 04:38 PM
sam12345
sam12345's Avatar
I have bought many used cars and I can tell you that if you take it too a good mechanic the inspection will be free and the peace of mind priceless. How can I claim the inspection is free? Because they will inevitably find something wrong with the car (hopefully a minor thing) that the seller did not disclose or did not know about. This then becomes a bargaining chip to lower the price and i have always been able to lower the price by more than the inspection cost me, hence it is free. Don't be a regretful fool and get it inspected.
Old 02-26-12, 06:12 PM
justablkv8
justablkv8's Avatar
Cam seals, and valve cover gaskets need to be replaced. My cost/average would be different than your normal mechanics so I suggest calling some places up ans asking them what a water pump/timing/cam/crank/valvecover job would cost.
You would need to do this anyway on a used car...
Old 02-26-12, 06:52 PM
GS300noob
GS300noob's Avatar
i just took my '99 gs300 into the toyota dealership a few weeks ago and had , water pump/timing/serp belt/tentioner and all cam seals done for $1050 , they were originaly just gonna do the timing stuff but the mechanic saw a leak on just the right side coming from the cam , and he recomemded that i replace all of them, it was only $8 per seal and about $150 for the labor , so not a bad idea to get done while they are doing the timing ect . i havn't seen a single drop of oil since.
Old 02-26-12, 07:15 PM
raytseng
raytseng's Avatar
if you're not doing this yourself, and you are not 100% sure exactly what part needs to be replaced,
you are better off just letting the mechanic handle ordering the parts, unless you're buying a load of expensive parts that you need to be specfiic. They are not idiots and can order parts too, and you can instruct and talk to them to pick higher quality ones .
Then you will be sure you won't be stuck with parts that you can't return, or invalidate the shop's worksmanship guarantee (usually 1year).
Old 02-26-12, 08:32 PM
LexiBlue
LexiBlue's Avatar
vvti sileniod vvti cam gear cam seals time for timing belt and water pump
Old 02-26-12, 09:51 PM
sam12345
sam12345's Avatar
If oil is leaking no matter how new the belt is you have to change it oil is not good for timing belts
Old 02-27-12, 10:01 PM
PUREADDICT
PUREADDICT's Avatar
Thank you all for the advice.
I cannot, however, find the "VVTI Solenoid" that LexiBlue mentioned I should replace. It was not on RockAuto. Also:
Originally Posted by LuxuryGS3
I believe all of them are OEM if ordered off of RockAuto.
There's a lot of different versions of the same part, and none of them say "Toyota" (which I would be guessing is OEM).
Old 03-08-12, 01:38 PM
MountieMan
MountieMan's Avatar
Camshaft oil seals a possibility. Might as well do the timing belt, too. Maybe $1500..... not worth it after 220K.
Old 03-08-12, 07:00 PM
LexiBlue
LexiBlue's Avatar
get oem seals the after market ones always leak. trust me oem seals
Old 03-08-12, 07:02 PM
PUREADDICT
PUREADDICT's Avatar
Update: I bought the car. Lol.
Thanks. Where should I purchase these? I don't think the ones on RockAuto are OEM..
Old 03-08-12, 08:46 PM
sam12345
sam12345's Avatar
Sewell parts online
Old 03-09-12, 05:47 AM
lexRydr916
lexRydr916's Avatar
Check those ball joints too. Those tend to go out quickly on our cars. G-luck
Old 03-09-12, 03:08 PM
PUREADDICT
PUREADDICT's Avatar
I heard the way to check for worn ball joints is to turn your wheel all the way left and right while you're at a stop and hear for clicking. I didn't hear any clicking or popping noises...
Old 03-09-12, 03:59 PM
lexRydr916
lexRydr916's Avatar
Yeah man you can do that or if you're test driving the car you can do a full u-turn and release the steering wheel. The steering wheel should return to center on its own. If it doesn't then you know the LBJ's might be bad. What part of Sac are you in?
BryanH19
04-08-19 04:01 PM
rerose
01-25-18 11:23 PM
brock125
02-23-15 06:27 PM
-Future-
01-22-11 07:22 PM
Jmai22
GS - 1st Gen (1993-1997)
06-04-10 01:12 AM
Quick Reply: Found a GS300, but now I need advice... (oil leak) *pic*
