Lifespan of Lower Ball Joints
I'll be doing a write up sometime soon, when I bought my car I replaced alot of things on it. Now I feel like second guessing everything is driving me insane.
So I'm going to be doing ball joints, control arms, bushings, steering rack, rear arms, diff bushings, rear frame bushings, etc etc..
Will post alot of pics and everything when I'm done.
I asked the same question and my mechanic said since the alignment adjustments are not touched.. then you most likely don't need one but to be safe nothing got knocked out of place... it'll be good to do so.
Well Beck doesn't manufacture Ball Joints they use various vendors to supply the product so you never know what you will get. I've seen plenty of BA stuff come in two boxes and have totally different brands and finishes on the same part number.. You likely bought the BA because they were cheap, and there is a reason they are, because their business is driven on price and volume, not product design.
So for the viewers out there don't base all aftermarket options out there on a crap company that don't actually make or at least design their own products.
These ***** Joint things are getting on my nerves
I replaced the lower ***** OEM about three months ago. Just past couple days the clunking resurfaced. Louder then what I have heard before. I took the car the local garage where I had the LBJ replaced. He said it should be OK. Should I be concern folks. My family is riding in this car. I replaced the original LBJ at 95K and it is now exactly at 98K. New Struts, OEM caster/trailing arm. I can't remember where I read it, But it does said with the poly urethane bushing in the caster/trailing arms, its can help ease the load on the LBJs. Is this correct? thanks all. The funny thing is that, the clunking resurfaced where it was starting to rain and the temperature was quite difference an hour earlier. The temp different in socal can be between 65 to 50 in a matter of hour or even less. Can't be the thermal shocked. Anyway I haven't heard the clunking lately.
FWIW, I've been one of the lucky ones. I've got 150K on mine, had them checked about 5 months ago when the car was in for a tranny flush, and they got a clean bill of health. I'm completely un-modded though, and always have been, I'm on 17" oem wheels...
No funny noises or vibration on mine either, and I've never had the "shakes" at highway speed with this car either, very smooth all the way to 100 mph,
When the time comes though, I'll most likely do the LBJ's myself.
I put on the left BJ on mine (waiting for some decent weather to do the right) and got Moog joints (on Amazon for around $54 each shipped) and Moog uses 3 Fives (japan company) for the actual joint. They probably have the arm cast and then assemble it.
Wouldn't be surprised if 3 Fives is the OEM supplier for Lexus.
I will be going with OEM bearings and Moog LBJ's
Mine where changed about 40k ago Ive been seeing all these horror stories of people snapping them and I drive way to crazy to not F something up if that broke....I feel better safe than sorry.
Was planning on doing Sway bar links and LBJs
can you identify the specific types of grease? I've read somewhere that you can not mix certain grease as the chemical reaction may destroy itself and be counter productive...i.e... hasten the failure.
