?? DO U KNOW: 99 & 00 GS 300 Throttle Body ??
Hello. New to the site...have searched hi & lo on this site and others but haven't found an answer....i'm hoping someone can help...
I have a 99 GS 300....
Anyone know if the Throttle Body is interchangeable with that of a 2000 GS 300???
HELP??
Thanks! Appreciate any pearls of wisdom!
HELP??
thx...i really just need the throttle lever assembly but can get a 2000 salvaged throttle body for the just a little more in price...may just go for the entire throttle body.
limp mode....vcs lights, ck engine....
lexus said it was either TPS or throttle control sensor...repl both and not fixed...
codes come up P1120 & 1121...next option (TMK) is the throttle lever assembly....
well if i were you honestly i wouldnt waste my $ on the lever assembly i been there done that . i ended up buying a throttle body off ebay for 250 and it came with all 3 sensors UNTOUCHED ! so all i had to do was uninstall my old TB and install the new one . plug the sensors up and walaaaaaaa problem solved ! o and unplug your battery while your doing this so the ecu can get reseted in the meantime !
heres the link of the guys i did business with...
http://www.ebay.com/itm/98-05-Lexus-...ht_1801wt_1037
You happen to have helped someone out tremendously by essentially giving it away at $60 shipped. Good deed for the day though..
