Red Coolant or Green Folks?
Old 03-01-12 | 12:23 AM
GS714's Avatar
GS714
Default Red Coolant or Green Folks?
I bought my 2001 GS300 about four months ago. I just did the timing belt and the water pump recently. The mechanic whose was working on my car noticed that the coolant in the system is Green. The coolant container I bought from Lexus of Westminster is RED. Should I flush the green out and pour the red in folks?
Old 03-01-12 | 12:37 AM
DosyBoy's Avatar
DosyBoy
Save yourself some time and go buy some green...
Old 03-01-12 | 01:16 AM
abounly's Avatar
abounly
Put OEM red stuff inside, make sure you dilute it with distill water.
Old 03-01-12 | 01:40 AM
VNN326's Avatar
VNN326
Red red red red red
Old 03-01-12 | 02:12 AM
Lextasy671's Avatar
Lextasy671
hmmmm...whats the diff with the red and green? when i got my IS250 i noticed it was red coolant..didnt really bother for it...
Old 03-01-12 | 09:58 AM
L3XOTIC's Avatar
L3XOTIC
Biggvinh....... its about time i tell you, nice avatar picture!
Old 03-01-12 | 10:00 AM
TheDream's Avatar
TheDream
the green coolant is the generic crap from the auto parts stores. It has a lot of additives to make it compatible with every car and so to stop small leaks. It's best to flush it out and put the OEM toyota coolant in there. The only time when you should stick with the green stuff is if the car is old with a lot of miles and drying hoses so if a tiny leak starts it won't get out of control.
Old 03-01-12 | 10:38 AM
FrankT's Avatar
FrankT
Green or red, but do not mix them.
Toyota red is made to last a long time, 6+ years, a lot longer than the green...
I use 'prestone' green and flush every two years. It's cheaper.
If you go with red, Toyota sells 2 kinds, full strength and 50/50 mix.
Make sure you buy what you intend.
Old 03-01-12 | 11:29 AM
ninja6o4's Avatar
ninja6o4
^^ +1 to everything Frank said. DO NOT MIX THEM.
btw, my vote is for red.
Old 03-01-12 | 12:54 PM
porn-adkt's Avatar
porn-adkt
Red ...........
Old 03-01-12 | 01:50 PM
Bippu147's Avatar
Bippu147
The red oem coolant is excellent. Use the red
Old 03-01-12 | 02:22 PM
FinLIFE's Avatar
FinLIFE
Oem red, no reason to go cheap its only a few dollars more
Old 03-01-12 | 02:30 PM
repugnante's Avatar
repugnante
Flush it out and go red. When I bought my car the coolant was orange/brown meaning someone had mixed green with the red (idiots). I had to flush the damn thing three times to make sure the system had nothing but red in it.
Old 03-01-12 | 02:32 PM
clos430's Avatar
clos430
RED..............
Old 03-01-12 | 07:54 PM
LexiBlue's Avatar
LexiBlue
red toyota coolantiszbest f**** that green ******
