Single Din dash kit with oem navi
i installed an aftermaket single din and i want to use the oem navi and climate controls. do they make dash kits for single dins with oem navi's ?
Alex,
My question was more in regards to the wiring, the face plate is custom and depending on the HU u get it will be a tad different. I can manufacture a custom faceplate, and don't need to worry bout paint since imma wrap it in 3m cf vinyl. I am very interested in the wiring though. I have the nav tool and a flip up single din DVD HU I want to put in place of the stock cassete player. Any info would be greatly appreciated.
Thanks,
cLos
Thanks,
cLos
To do this you will have to run new speaker wires and get an aftermarket amp, 2 amps if you're adding a sub or use a 5 channel. On the cassette section, there is a plug with two wires that needs to stay plugged in for the navi and temp controls to work. You can extend the wires and move it to the glove box or trunk. A good place would be where the stock cd changer is. I plan on going double din by removing the ashtray and do a custom fit.
2jzaristo1
15
09-07-10 09:01 AM
