AUX input for under $5.00*** You guys wont be disappointed Pic intensive
Old 07-21-12, 01:37 PM
  #61
PinaQkoNga
PinaQkoNga's Avatar
This mod cost me like $3! Why do I like Frank Ocean? Idk...
Old 07-21-12, 03:46 PM
  #62
sam12345
sam12345's Avatar
Originally Posted by ThomasGS4
Looks cool, but you'd have to unplug your iPod/Phone every time you want to change or look up a song. Not to mention, you can't exactly put it all back to stock without buying another head unit.
What I'm thinking is to pass the cable through and connect it to my fake tape with a hinge. So I pop the tape in with the iPod and it hinges out so that the iPod is exposed and easy to get to, I would angle it and maybe a small twist towards me.
Old 07-21-12, 03:51 PM
  #63
ThomasGS4
ThomasGS4's Avatar
Not a bad plan. Be sure to post pictures if/when you do this.
Old 07-21-12, 03:56 PM
  #64
sam12345
sam12345's Avatar
I did I search and it's already on the market except I will use the aux cable instead of the tape head and run the power cord through the inside of tape so there are no exposed cables
http://www.geardiary.com/2009/05/20/...nt-with-audio/
Old 07-23-12, 04:09 PM
  #65
sam12345
sam12345's Avatar
I found this.
Amazon Amazon
This way I put it in the center console and presto instant connection to my iPod with no cables. When I get it I will report. Got mine on eBay for less than 8 bucks. So 8+5 = 13 bucks for blue tooth on our old Lexus. Not bad
Old 07-23-12, 04:48 PM
  #66
Highway
Highway's Avatar
After looking back a few times i think a black cable would look much better in your car OP. Dope DIY thx for sharing!
Old 08-05-12, 04:00 PM
  #67
sam12345
sam12345's Avatar
I got my blue tooth and intalled it. Ran into a problem, alternator noise through the speakers. To solve this problem I ran the cig lighter ground, and the aux cable ground to a bolt that holds the amplifier (this way everything has the same ground). Problem solved. Then I tried different cig lighter to USB adapters. All of them made a buzzing sound except the Belkin mini adapter. Now I am good to go. And my iPod connects with no wires. Here is a link to the Bluetooth device. If you want to wait longer you can get it on eBay for a little more than 7.00 dollars.
Amazon Amazon
Old 08-09-12, 10:45 PM
  #68
riddleme1
riddleme1's Avatar
Forgive me if this is a dumb question, but are you only using one half of the speaker wire (positive or negative)? Cutting 5 one foot strips of speaker wire would technically be 10 pieces if split. Am I missing something? Thanks for posting this write-up. I've bought the audio jack and would love to get this installed by the end of the weekend.
Old 08-10-12, 08:43 AM
  #69
PinaQkoNga
PinaQkoNga's Avatar
Yes 1 half. You shouldn't have 10.
Old 08-10-12, 11:44 AM
  #70
riddleme1
riddleme1's Avatar
thanks for the reply PinaQkoNga. what do i do with the other half then? i have 50 feet of speaker wire. if i cut five 1 foot segments and only use one half (let's say the positive side). what are the negative side portions of the speaker cable doing? again i apologize if these are basic questions
Old 08-10-12, 12:18 PM
  #71
PinaQkoNga
PinaQkoNga's Avatar
Just toss it or re-use it. As long as you solder/connect the wires to the correct pins on your jack & make sure you ground it.
Old 08-10-12, 12:21 PM
  #72
riddleme1
riddleme1's Avatar
thanks i appreciate the guidance
Old 08-10-12, 12:32 PM
  #73
riddleme1
riddleme1's Avatar
one last question...where do you recommend i ground? should i just use a factory screw close by?
Old 08-10-12, 12:41 PM
  #74
PinaQkoNga
PinaQkoNga's Avatar
I used one of the bolts that's holding up the whole CD changer. You can hear the engine in the through the speakers a little as you drive but only if you don't have anything playing. With the musics bumping, you don't even hear it(noise).
Old 08-10-12, 06:54 PM
  #75
sam12345
sam12345's Avatar
Use the bolt that holds the amplifier because that is what your really tapping into. If will get rid of the alternator whine if you do
Quick Reply: AUX input for under $5.00*** You guys wont be disappointed Pic intensive
