RMM STB - will spacers work on GS300?
I remember having the same problem when I installed my RMM strut tower brace. I think you just have to readjust the length of the brace. I know I even removed the factory spacers that were present prior to the install. I'll take a look at it tomorrow and let you know.
Globe, the RMM might clear the engine cover in a 300, because it's thin not bulky and round like the Tom's and TRD STB's... The only other thing I can see if it does clear is maybe it'll sit too high and interfere with the hood closing...
GS3, you can get spacers at your local Toyota/Lexus dealership..
The reason you were having problems with the fit, is because you have to jack the front up off the ground to release the pressure from the struts... I had the same problem but when the frontend was off the ground the bolts shifted and bamm it was in....
Originally posted by LVgs400
Very good point Sypher. Is there any write-ups for DIY installation?
Yes, Manaray did a writeup a while back... There may be a couple of others too.
Link 1 (Manaray) Front and rear STB install
fireballs gs400
09-27-03 09:12 AM
