Anyone running aftermarket Engine management?
Hey everyone,
Coming to the point in my build where i have to consider engine management. (VVTi 2JZ into 2000 GS300)
Im settled on an Autronic SM4 with a 2JZ plug and play loom.
My question is, is there any part of the body electrics that require the factory ECU to work?
By body electrics i mean anything not associated with the operation of the engine directly.
The car is going Manual so i dont need to worry about keeping functions related to the Auto transmission.
I.E do i need to retain the Factory ECU and wire the Autronic as a piggy back to control engine parameters in order to have everything work properly?
Any info or experience with this would be sexcellent!
I haven't, check on Lextreme, they might know much more.
What is your goal with the piggy back?
Hey everyone,
Its not an actual piggy back. Its a stand alone system. however if i need to retain the factory ecu to keep full functionality of the vehicle then ill wire it to control engine parameters on the factory ecu.
tu2
12-22-16 03:21 PM
XeetBMW330ci
07-04-03 10:35 AM
