65mph+ shake fix
I still don't understand what you are trying to prove about what I said.
Polyurethane bushings as a whole are made to counter the problem of deterioration of original rubber bushings while not increasing vibration or harshness in ride.
If you were to replace a poly or rubber bushing with a solid bushing you will increase vibration by as much as 80%. Essentially you are fusing the parts.
Just because the actual shaft, rubber and bearing deteriorate doesnt mean we automatically place a solid bushing in place of the poly or rubber bushing.
Furthermore; there should be some movement within the steering rack. Very negligible movement at that.
We're replacing parts on out 10+ year old vehicles that have deteriorates due to usage and various weather conditions but were also replacing it with parts that are of a "upgrade" of sorts but also that have not been tested for 100,000+ miles.
Links for bushings
Front-
Rear-
http://www.ebay.com/itm/18-1124-GS30...d49430&vxp=mtr
Rack Bushing---Highly Recommended
http://cgi.ebay.com/ws/eBayISAPI.dll...m=120868833083
Front-
Rear-
So it looks like you nailed it! Congrats!
After all this supsension work that I have done to my GS changing out inner ball joints, I believe made the biggest improvement when it comes to shake. As for handling obviously Daizen bushings and steering pre-tensioner.
Btw how much diod it cost you to do force-balance? I remember looking into it while back but it was almost like $200 here in Nor CA.....
Paulanth
12-16-18 08:46 PM
