Starting Problems Intermittant...
Old 03-17-12, 03:22 AM
RSpi
RSpi's Avatar
Default Starting Problems Intermittant...
I'm trying to help my friend with his GS300. Sometimes it does not start. I'm thinking he may have a problem with his fuel pump relay due to the fact that the problem is intermittant and when it heppened while I was there, I could not hear the fuel pump whine.
Can someone tell me where the fuel pump relay is located and how to access it. A photo would be great.
If someone thinks there is another issue please let me know. He has a P0154 code and P0405 (I think). We replaced one of the O2 sensors a week or so ago and plan to replace the other one soon.
Thanks.
(BTW, I did a search in google and on this section of the forum and could not find any FPR issues).
Old 03-17-12, 08:57 AM
GS4_Fiend
GS4_Fiend's Avatar
Fuel pump relay is in the engine compartment. Its called Circuit Opening relay
Old 03-17-12, 11:13 AM
RSpi
RSpi's Avatar
Any idea which side of the engine compartment? I seen 3 different panels under there.
Thanks for help.
Old 03-17-12, 02:06 PM
GS4_Fiend
GS4_Fiend's Avatar
There should be labels under the box
Old 03-17-12, 05:33 PM
RSpi
RSpi's Avatar
Looked under the lid of each box and seen nothing that indicated the Circuit Opening Relay or Fuel Pump Relay. I looked behind the parking brake and seen the fuse panel and a relay on top of it which I could not get out that was large enough to be one. I'm still lost.
Old 03-17-12, 05:41 PM
GS4_Fiend
GS4_Fiend's Avatar
try the driver's kick panel
Old 05-16-12, 04:23 AM
RSpi
RSpi's Avatar
Still having intermittant starting issues. Usually after a refuel.
I pulled codes yesterday and they are as follows:
P0153, P0154, P0430 and (drum roll please), P2197.
We changed the b2 s1 o2 sensor. I plan to change the B2 S2 sensor today to see what happens after that.
nicks88
08-23-13 07:12 PM
NSeagle78
Performance & Maintenance
09-30-12 12:49 PM
nhlrules8
12-11-09 01:19 AM
sc300vroom
SC- 1st Gen (1992-2000)
11-07-09 08:31 PM
Ridg Ryan
10-22-08 12:16 PM
Quick Reply: Starting Problems Intermittant...
