GS300 Knock Sensors Locataion (p0325)
Old 03-20-12 | 09:10 AM
Micdizo's Avatar
Micdizo
Default GS300 Knock Sensors Locataion (p0325)
My car is giving me a P0325 code and I would like to switch the knock sensors to see if the error changes to the other side. I am just not sure where they are. Can someone let me know an if possible attach a pic. I have searched the forum but only seen where they are on a GS400. Thanks in advance.
Old 03-20-12 | 09:36 AM
mexikan's Avatar
mexikan
Wink
(check your oil level) there's 2 sensors they're both on the left side one has a black wire is in front ,the other one has a grey wire.and its toward the back under the manifold..they're bolted on to the engine block...hope this helps..
Old 03-20-12 | 09:47 AM
Micdizo's Avatar
Micdizo
Thanks alot. And the oil probably is a bit low. I guess I should do the oil change first.
Old 03-20-12 | 11:24 AM
mexikan's Avatar
mexikan
Thumbs up
no problem.. yeah do your oil change first..clear your codes and drive it and see if code comes back.. btw i work for a repair shop so i have access to wiring diagrams and such.. info
.. sorry no pics dont have a smart phone or camara on hand.. p
Old 03-20-12 | 05:36 PM
Micdizo's Avatar
Micdizo
oil change did not do it. When you say left side do you mean the left when looking at the engine(passager side) or the drivers side? I am still trying to find the sensors.
Old 03-20-12 | 05:43 PM
99 GS3's Avatar
99 GS3
driver side, directly under the intake manifold. Quicker and easier to go at it from the bottom if you have access to a lift.
Old 03-20-12 | 06:21 PM
Micdizo's Avatar
Micdizo
i am preety sure i fount it. It has just one wire going into it right? Well the wire seems to be pulled out of the connecter i tried to push it back in, but the rubber part on the wire wont go in. Can i buy just that connector?
Old 03-20-12 | 06:37 PM
99 GS3's Avatar
99 GS3
Yeah they only have one wire. Pretty common that it just becomes brittle and breaks off from the heat buildup.
Yes you can get just the connector from toyota, but the dealership can't just look up connectors they only show the harnesses. If you take the broke connector off the sensor there should be a part number on it. They can order individual connectors if you provide the part number.
Old 03-20-12 | 08:04 PM
Micdizo's Avatar
Micdizo
thanks i will pull the connector off and take it to the dealer. Thanks for all the help guys!
Old 03-22-12 | 07:49 AM
Micdizo's Avatar
Micdizo
I took the plastic connector out yesterday but there is no number anywhere on it to be found. Is there another way to get this number?
Old 03-22-12 | 08:38 AM
99 GS3's Avatar
99 GS3
See my replies in your other post about the engine harness, I think you will find what you need there.
Old 03-22-12 | 10:04 AM
vwynn's Avatar
vwynn
knock sensor is under the intake manifold.
Old 03-22-12 | 10:09 AM
vwynn's Avatar
vwynn
goddam i was late lol... mybad
Old 03-22-12 | 10:25 AM
99 GS3's Avatar
99 GS3
^^^^^^ Late and ill prepared
That's a 400 he has a 300... The picture is no good, but your description still applies as on the the 300 they are under the intake manifold as well, it's just that the manifold is in the side of the motor not on top like the 400.
Don't be so hard on urself, and btw you gots a dirty mouth son.
Old 03-22-12 | 12:05 PM
vwynn's Avatar
vwynn
rats decided to take shelter under there... haha its cleaner.. now... ish
yea i saw the word "GS400" n thought he had one. didnt read it until now.
i hate my baby FMIC compared to your huge one..
