finally found a mechanic to install my timing belt, are these all the parts I need?
https://www.clublexus.com/forums/gs-...w-to-soon.html
searched the forum and found this thread. Are these all the parts I need to replace my timing belt?
Also does anyone have the part#'s handy for these parts because i'm gonna order all these parts this weekend.
Thanks in advance guys. U have helped me out tremendously already,
Scott
Scott
have a 2001 gs430 with 89788 miles on it
On my service I did the following:
Timing belt, water pump, cam seals, oil pump seal and I had to change out the cam gear pulley because it was seized on my cam.
Probably missing something but do everything in there once its apart because you'll be paying 2x for it to go back together.
The key is to talk to the mechanic and let him know to inspect and evaluate hings while he's in there and give you a call with recommendations for anything else to do once he's got everything taken apart.
If they are any good at all, they have access to parts that they can get within hours, and not at an onerous price.
Otherwise you may be missing both ways, either buying and changing parts that are still good, or not changing parts that will fail soon.
All I want is:Accessory belt: $46
Water pump: $105
Gasket: $6
Crank seal: $10
Timing belt tensioner: $45
I already have the timing belt, anyone know where I can find these part #'s?
whazzzzuup
10-29-20 04:05 PM
