Rotor UPgrade?
can i run ls400 rotors on the gs? no bbk upgrade. and would i need the whole setup. i will have stock gs calipers, just putting on ls400 rotors since its bigger.
You can do the whole LS400 setup. I don't believe you can use LS rotors with GS calipers, just seems logical that it won't work.
You can pick up some LS400 Calipers for like 160, then get some 17MM RCA's for around 180 or so to clear the LBJ. Also on stock wheels you have to run 15MM spacers to get them to fit without hitting the wheel.
