Sway Bar Bushings Question
On a 1998 GS 400 are the Front Sway Bar Bushing Readily Accessible once I lift the car, or do I have to remove the Engine Splash Shield first in order to get to them? I am getting ready to replace them. Also how easy are the rears to access? Thanks in advance, guys.
I installed my new bushings. I haven't noticed too much of a difference in the way the car drives since I installed OEM Bushings. I am still getting a squeaking sound from my car going over small dips. Not sure what to replace next. I have already done Caster Arms, Lower Ball Joints, Out Tie Rods, Sway Bar Links, and now Sway Bar Bushings. I'm not sure how old the shocks are, but I know they have been replaced at least once. I might have to look into the shocks and shock mounts next.
I'm also still getting an annoying rattle going over bumps when my brakes are decompressed that I need to figure out, I think the pads are jiggling around or something. When I brake the sound disappears.
Anyway's thanks for the quick answer earlier about the install. I still have to put the Splash Guard back on. I think the longest part of this DIY was the time it took me to jack up and put the car on stands.
If you look at the following items. I think the upper mount(item #13) and the bump stopper( item #14) would be the next step. I have talk to two mechanic, and both suspecting the two items I mentioned. I hated to say this, But I think, and I hoping that the Lexus Technician was wrong, The squeaking noise could be coming from the strut itself. I was told. I just replaced all four struts not too long ago, about 5 months now. Please let me know if can narrow it down.
