1JZGTE swap in to a 2GS ?? ??
not much at all on that swap, I remember seeing one recently about a guy in Ireland. The 1JZGTE is more accessible over in europe right? If you do, you would need to get one out of a chaser and I would highly recommend getting the VVTI version
you can put a 1jzgte in a gs, but depending on the gs year 98-00 you can put a 2jzgte.The 2jzgtevvti motor is if you have the triptronics 01-05 gs you can manually shift throught the steering wheel. otherwise 1jz or 2jz non vvti would worki either way hopes this helps.
Its pointless to put a 1J in because it doesnt bolt right in the 2GS like it does the SC. You'll spend just as much $$$ making a 1J fit than just swapping a 2J-GTE. Thats why nobody has ever done it before.
The single turbo vvti 1j is a good engine. And it can be had from chasers, soarers, mark II's, and a couple other vehicles.
