Passenger rear window doesnt work
The switch used in the Passenger rear window doesnt work, however I can move the window up and down fine from the master window controls. I'm hoping its a cheap fix, anyone know what part I need?
FIXED
FIXED
Could be the switch malfunction on the pass side rear.
Do you see any power going to that side in the switch? Easiest way to tell is to just wait till nightfall/dark (garage maybe) and turn on the headlights and the controls should light up.
Also you can remove the other rear pass and plug it into the side thats not working and see if the switch works then. If it does then you know your culprit.
I dont have the info on hand but check to see if theres a rear door/window fuse on the lower front kick panels.
05ls430518
02-26-18 08:40 AM
KiNGD206
01-10-14 07:13 PM
