strange power lock/unlock issue
Old 04-18-12, 10:57 AM
SureShot
SureShot's Avatar
Default strange power lock/unlock issue
so i attempted to fix a friends pass. front lock actuator today. i had an extra motor from when I repaired mine. everything went smoothly, except when i press "lock" on the driver's door (or key fob), all doors lock but the pass front door unlocks. When i press "unlock" on the driver's door (or fob) all doors unlock but the pass front door locks. i took everything back apart and verified the install. if you have done the DIY before, you know that the motor only has terminals on one side, so the motor can't be reversed. any ideas? my first thought is a defective motor.
Old 04-19-12, 10:25 PM
BIGMerle
BIGMerle's Avatar
..........bump
Old 04-19-12, 11:02 PM
1sWt2GS
1sWt2GS's Avatar
it seems to be viral, everyone (including my door lock actuator has been going bad later)
it might be a defective motor, they seem to be pretty cheap if you find them on ebay.
keep in mind even with the lock failing, it still attempts to lock, in your case it sounds like its not working period.
Old 04-20-12, 05:07 AM
SureShot
SureShot's Avatar
No it works fine. It just works backwards. Lock actually unlocks and unlock actually locks. Only the motor that was replaced. I'm still leaning towards a defective motor (internals installed incorrectly).
Old 04-20-12, 09:50 AM
BIGMerle
BIGMerle's Avatar
maybe switch the pins on the harness?
Old 04-20-12, 10:49 AM
ninja6o4
ninja6o4's Avatar
Try this. might be the easiest way to solve it, short of changing the motor again.
Old 07-11-13, 11:43 AM
iamkhanz
iamkhanz's Avatar
erased and posted as my issue is a bit different. ... all 4 doors working opposite.
https://www.clublexus.com/forums/gs-...ml#post8033954
pernjiepoi
04-23-22 07:23 PM
CRAIGF
RX - 3rd Gen (2010-2015)
02-03-18 09:45 AM
Foob
04-22-16 11:03 AM
islexusred
12-03-13 02:26 AM
khilgers
06-15-12 03:20 PM
Quick Reply: strange power lock/unlock issue
