Help! Rear Passenger Wheel *Video Inside*
Old 04-19-12 | 12:19 AM
sikkwidit's Avatar
sikkwidit
Default Help! Rear Passenger Wheel *Video Inside*
Wassup guys Im having a issue with my car right now, as I was getting home tonight I was looking for a parking and as I reversed I heard a noise come from the rear passenger side so I turned down the music and this is what I heard..
http://youtu.be/ZXRPGzjFzHU
I recently replaced my front and rear sway bar bushings and had E break and break pads replaced about a year ago this month. Also installed spacers a couple months ago. Any idea what it can be?
Old 04-19-12 | 09:56 AM
justablkv8's Avatar
justablkv8
have you tried to spin the rear wheels by hand and jack up the car to see if it persists?
Old 04-19-12 | 10:00 AM
sikkwidit's Avatar
sikkwidit
Not yet, Im going to try that right now
Old 04-19-12 | 10:28 AM
JLAWS's Avatar
JLAWS
Sounds like the dust shield behind the rotor is rubbing the rotor.
Old 04-19-12 | 01:03 PM
vipXjunky's Avatar
vipXjunky
thats PROBABLY a BINGO because it happend to me on the front side passenger..I just pushed it back alittle and the problem went away.
Goodluck!
Old 04-19-12 | 06:47 PM
sikkwidit's Avatar
sikkwidit
Goodluck!
I bent the dust shield back and it didnt work I checked my breaks n they still have good life on them and the disk has no sign of scratch or rub on it.
Could it maybe be the ball bearings? or axle?
Old 04-19-12 | 07:53 PM
02Legend's Avatar
02Legend
Check this out. I just recently changed my rotors and pads all around. I have had this issue on my IS300 as well. The groove slot, or however you want to call it was causing grinding. I ended up pulling the rotor off and grinding down the rotor groove a little on the bottom and the noise has stopped.
Might just want to check it out. The noise was an annoying scraping noise, but would get louder if I put a load on it by turning.
Attached Thumbnails Help! Rear Passenger Wheel *Video Inside*-back_plate.jpg   Help! Rear Passenger Wheel *Video Inside*-groove.jpg
Old 04-19-12 | 11:48 PM
sikkwidit's Avatar
sikkwidit
Im going to check this out tomorrow morning it looks like that can be a problem. Thank You bro!
Smitslex
01-28-24 09:08 AM
ThumperPup
ES - 5th Gen (2007-2012)
08-03-15 11:43 AM
vipXjunky
04-25-12 12:00 PM
Stage3
Suspension and Brakes
06-23-08 06:01 PM
Tommy K
07-21-04 12:23 PM
