Anyone has good or bad experience with after market Moog ball joint?
Old 04-20-12, 02:22 PM
GS4TEK
GS4TEK's Avatar
Default Anyone has good or bad experience with after market Moog ball joint?
After reading the warning about ball joints on GS MODEL from 1998-2000 ball joints, I wanna replace mine but some member reported that after 2 wks with oem ball
joints replacement, it went out on him. I know federal mogul brand Moog ball joints are cheaper but anyone has any experience with hat brand?
Please share... Thanks
Old 04-20-12, 08:20 PM
lexo98
lexo98's Avatar
The post I read about a balljoint going out in 2 weeks was on a car that was bagged.
Old 04-21-12, 04:50 AM
rogzballz
rogzballz's Avatar
They should be fine for oem spec suspensions. But for lowered cars you should be looking at extended lengths or extended range ball joints.
http://www.horsepowerfreaks.com/part...lignment/11148
http://www.horsepowerfreaks.com/part..._Joints//18583
Old 04-23-12, 10:03 PM
GS4TEK
GS4TEK's Avatar
Thanks for all the helps guys!!!
Old 04-24-12, 01:05 AM
YviE
YviE's Avatar
Are those actually available for the GS?
Old 04-24-12, 06:13 AM
SaiyanGS3
SaiyanGS3's Avatar
Go with Moog if you are smart. Great product, cheaper, and produced in Japan. I have Moog lbj's and tie rods for the price of the faulty oem lbj's.
Old 04-24-12, 08:36 AM
oslouie
oslouie's Avatar
Moog is awesome. I have 16k on mine and no problems yet.
Old 04-24-12, 10:04 AM
vwynn
vwynn's Avatar
i still dont understand why people still think OEM is faulty.. they last like 100k miles in a stock car. lol.. so its obviously working the way its designed to..
also, its a wear and tear item guys.
WEAR AND TEAR = REPLACE when WORN OUT.. its not a LIFETIME NONREPLACEMENT ITEM.
cmon guys.
as for Moog. lotta peepo said its good. havent had first hand exp though.
WEAR AND TEAR goddamit.
Old 04-24-12, 11:40 AM
Sonic_RC
Sonic_RC's Avatar
Moog's are good quality. They are probably the best OEM replacements you can get and good price.
Old 04-24-12, 12:16 PM
d7620
d7620's Avatar
if i remembered correctly, i read somewhere that Moog's products might even be better then OEM parts.
Old 04-24-12, 01:11 PM
pinoy8317
pinoy8317's Avatar
I got triple 5 ball joints from japan i havent heard of any other brand
Old 04-24-12, 03:22 PM
lexusben
lexusben's Avatar
cmon guys.
On a true stock suspension I'm sure OEM could last even longer than 100k. I had OEM Ball Joints until I replaced them around 140k and I am on Eibach Springs (have been for 100K). Even though Eibachs only provide an inch of drop the suspension takes a lot more of a beating than with the OEM Springs because of the upgraded Spring Rate.
I replaced my Ball Joints with OEM and I won't be changing them for another 100K assuming my car gets there.
As for Moog, I installed Moog Sway Bar Links this Winter. They have already begun to rust in the short span until now.
I know that rust on the metal isn't really a big deal and that the ball joints are what matter, but either way I would rather not see rust on a 3 month old part.
I guess my opinion is that right now Moog is fine, but I would still take OEM.
Old 04-24-12, 04:45 PM
RoninEng
RoninEng's Avatar
Have moog lower bjs sitting at my shop waiting for my coils to arrive so I'll chime back In after install. I like the fact that they have grease fittings. Anything that you can lubricate over its life span is a plus
Old 04-26-12, 02:58 PM
GS4TEK
GS4TEK's Avatar
Thank u all CL members
Old 04-26-12, 06:24 PM
Sonic_RC
Sonic_RC's Avatar
Moogs are actually made by 555. If you look really closely to the moog LBJ you can see the 555 stamp
Quick Reply: Anyone has good or bad experience with after market Moog ball joint?
