HID Question
iModerate
If you plug in a new bulb and it still will not come on the ballast may have failed and will need to be replaced.
No, I thought OEM D2R plug between bulb and ballast is different than aftermarket HID for D2R bulb.
With aftermarket HID kits, I think you need these adapters- http://store.ijdmtoy.com/AMP-Convert...adapter_01.htm
Ref -
Ref -
iModerate
Ref - http://www.amazon.com/Toyota-Lexus-B.../dp/B0040P5LKU
As a side note I just replaced my factory HID bulbs with aftermarket bulbs because one bulb burnt out.
Former Sponsor
818GS - As others have noted, any D2R HID bulb will work. Also, if you want to retain the stock HID look you will want 4300k for the color temperature - all cars that come with factory installed HID headlights use 4100k-4300k bulbs.
its either 4.3k or 6k to my knowledge.
in person difference to picture difference is going to be different. its like listening to an exhaust over youtube before purchasing it.
to help you out, 4.3k is more OEM (white)
6k is blueish white (defintely notice the blue)
8k is totally blue
keep in mind my scale is give or take.
iModerate
Former Sponsor
A 6000k bulb is rated at approximately 20% less lumens than a 4300k bulb. Lumens is what determines the actual light output of the bulb. A 6000k bulb may appear to be brighter than a 4300k bulb as the "bluish" tone creates more of a contrast however less light output is actually being emitted. A 5000k bulb will offer you a cool white output. It will be similar to 4300k however it will be more on the "cooler" side i.e. no yellow at all. I don't have any comparison pics showing both but here is a good pic showing the difference between OEM 4300k and XenonDepot 5000k:
6000k starts getting you into noticeable blue output.
Steve
Steve
