bank 2 sensor 1 o2 sensor...how the hell?
04-26-12, 04:38 PM
How the heck do you change this sensor without taking off the header? I dont see enough room back there for an o2 socket. All help is appreciated!
04-26-12, 04:39 PM
BTW, this is the one between the header and firewall!!!
04-26-12, 05:17 PM
I used a regular wrench to get it loose then used my hand to twist it off after disconnecting the wire. Be gentle with the wire though.
04-26-12, 06:25 PM
You can use an offset O2 sensor socket. You can pick them up at most auto parts stores.
04-26-12, 08:52 PM
Believe it or not, labor rate for doing Sensor 1 (Fronts) is .5. And doing Sensor 2 (Rears) is 1 hour. So, technically it should only take 30 minutes to do the fronts.
04-27-12, 09:42 AM
04-27-12, 10:56 PM
Quote:
Originally Posted by
speedaddic
22mm wrench...cake
QFT.
SMUChris
12-17-12 03:50 AM
Aristo300
02-12-08 01:00 PM
2004 ,
2008 ,
bank ,
bank2 ,
change ,
es330 ,
gs300 ,
gx470 ,
is250 ,
lexus ,
location ,
o2 ,
postition ,
sensor ,
sensor1 ,
tool ,
wrench
