KEY PROGRAMMING for 98-05 gs300 400 430
Old 09-20-12, 10:02 PM
SDGSPW
SDGSPW's Avatar
Thanks for the input. I'll make a few phone calls around town and see what I come up with.
Old 09-21-12, 07:31 PM
RXGS
RXGS's Avatar
Dealership here charges $35 dollars to program a key
Old 10-14-12, 06:21 PM
celm
celm's Avatar
great write up
+1 to make it a stickey
Old 10-15-12, 12:01 PM
SDGSPW
SDGSPW's Avatar
Scottsdale Lexus wants $75 to program a key. I'm going to try Bell Lexus now to see if they are any cheaper.
Old 10-16-12, 10:40 AM
Rasta1
Rasta1's Avatar
Where can I purchase a spare key?
Old 12-13-12, 07:29 PM
SaiyanGS3
SaiyanGS3's Avatar
super bump...why isn't this in the sticky??
Old 12-21-12, 04:32 PM
veron1987
veron1987's Avatar
works! took me 2 mins to program a key i purchased from Sewell Lexus - $162.01 cut and shipped.
Old 12-21-12, 04:58 PM
celm
celm's Avatar
Does this programming method work on a fob that was programmed to.another car
Old 12-23-12, 07:01 PM
veron1987
veron1987's Avatar
i believe so.You can try to and see if it works.
Keep in mind it might not work again in the other car even if it does not work when you try it.
keep us posted.
Old 02-10-13, 12:37 PM
LATINA2001
LATINA2001's Avatar
Help needed ....I lost my keys and got one remote master key from Sewell ...I tried programming following the instructions given and haven't been successful . I have a 98 gs 400 and the front passenger lock doesn't respond to commands from the electronic door locks on the car...would that have affected the programming and if so any work arounds ? Thanks
Old 02-10-13, 04:36 PM
paul1012
paul1012's Avatar
just about what i needed
Old 02-11-13, 08:35 PM
rotor
rotor's Avatar
Thumbs up
Subscribed
Old 02-13-13, 11:36 AM
MCBob
MCBob's Avatar
I can follow the first 9 and get the cylce of clicks, but nothing of the following really seems to work..
What security light am i looking for? I have what looks like an aftermarket LED with a small slot under the dash, but that may be stock, I dont know.
I drive a JZS161 which may be slightly diff, but the programming mode does work.
All help appreciated!!
1. Insert an already programmed master key into the ignition. Do not turn.
2. Press and release the gas pedal 5 times.
3. Press and release the brake pedal 6 times.
4. Remove the key from the ignition.
5. Insert the new key you want to program into the ignition.
6. Press and release the gas pedal one time.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your key is programmed. To end programming step on brake one time.
NOTE: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will come on and start to blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
If you perform this procedure too slowly your car will not go into programming mode. If you can not get your car to go into programming mode make sure you are using a master key and not a valet key. If you have a master key then you will probably need to perform this procedure more quickly.
Read more: https://www.clublexus.com/forums/gs-...#ixzz2KoFXsbXk
Old 02-13-13, 11:49 AM
Cartune
Cartune's Avatar
Thx for the write up
Old 02-13-13, 12:13 PM
Advil4u
Advil4u's Avatar
so i got my hands on a brand new toyota wireless entry key it is still uncut my question to better understand is i still gotta get it programmed to start my car i currently am using my valet key
Quick Reply: KEY PROGRAMMING for 98-05 gs300 400 430
