KEY PROGRAMMING for 98-05 gs300 400 430
Old 02-17-16, 09:52 AM
  #106
lexo98
lexo98's Avatar
Originally Posted by 2k4CamkilA
MY CAR DOESN'T GO INTO PROGRAMMING MODE. IT NEVER CYCLES THE LOCKS. i'M DOING THE SAME WAY THE WRITE UP SAYS. I EVEN WATCH SPEEDKAR'S VIDEO ON YOUTUBE WHILE I DID. MY CAR NEVER CYCLED THE LOCKS. BEFORE HAND I JUST PROGRAMMED THE NEW KEY TO THE IGNITION
Did you manually lock/unlock the doors with the inside door lock? If i remember right if you use the electric switch and the door lock actuators are weak it won't go into program mode so you need to use the manual lock
Old 03-01-16, 11:39 AM
  #107
2k4CamkilA
2k4CamkilA's Avatar
I tried to do it manually by the lock and it still wouldn't go into programming mode
Old 03-01-16, 01:40 PM
  #108
ShunDoe
ShunDoe's Avatar
I believe this has some truth to it. I tried programming the key to the ecu to start up the car and was successful but when I tried to program the lock/unlock/trunk it wouldn't cycle all the way through and that's due to weak actuators. Those are about $50 a piece that last time I checked
Old 03-01-16, 01:42 PM
  #109
LexusK
LexusK's Avatar
You guys are all replacing lost keys correct? Can I just replace the black case on my key? I have a viper alarm that locks my doors, so I don't really need all the programming stuff. Case is cracking and is being held together by black electrical tape :P
Doubt reprogramming a key would work since my actuators are basically shot and need to be fixed before I try it.
Old 03-01-16, 01:45 PM
  #110
ShunDoe
ShunDoe's Avatar
You can find those on eBay for no more that $10-15. I have a push start on my 2GS that come with keyless entry and proximity unlock, but I got an extra Lexus oem key made just in case.
Old 03-01-16, 01:49 PM
  #111
ShunDoe
ShunDoe's Avatar
I haven't tried it but I'm thinking about it. Which ever door look has the actuator problem, maybe have some help you out and lock and unlock that door as you follow the steps to program the lock and unlock
Old 03-01-16, 06:39 PM
  #112
LexusK
LexusK's Avatar
The descriptions on ebay say to transfer the internals to the new key and have the blade cut. Is it possible to just take off the old case and put the new one on? A lot of reviews say that the new blade is not a good match...
Old 03-01-16, 07:52 PM
  #113
ShunDoe
ShunDoe's Avatar
That is possible with the button part of the remote, I'm not so sure when it come to the key. If you do have to get a key cut Lexus charges $35. But I would say see what you can find on YouTube university about swapping them out
Old 03-07-16, 06:25 PM
  #114
speedkar9
speedkar9's Avatar
Originally Posted by Goosesedan
so my question is this, i just bought a Lexus Gs 300 and it only came with 1 valet key, the key doesn't open the trunk, how do i get a new key to be able to start the car, open the trunk, and keyless entry without going to the dealership?. Thanks
You will have to virginize your ECU or Transponder ECU's EEPROM where the keys are stored to put the car into auto-programming mode to accept new master keys.
Please check out my video and DIY writeup below on how to do this:
https://www.clublexus.com/forums/es-...apped-ecu.html
Old 03-10-16, 11:40 AM
  #115
xxjeffxx
9th Gear
xxjeffxx's Avatar
Thanks! i'll keep this in mind when I get a new key!
Old 03-16-16, 02:14 PM
  #116
sbagdon
sbagdon's Avatar
Default Programming a Valet Key?
I've read the thread, yet don't see how to program a valet key. The only instructions are programming an additional master key.
Did I miss the instructions, are they not known, or is there a resource to get these instructions?
Thanks!
Old 03-16-16, 04:49 PM
  #117
GS3KID
GS3KID's Avatar
Thanks!
If I'm not mistaken you can't program valet keys because it shouldn't have a transponder(the computer with lock buttons).
Old 03-17-16, 05:53 AM
  #118
sbagdon
sbagdon's Avatar
You can't program valet keys for RKE (if they lack the transponder, ok, yes people have programmed RKE keys as valet keys, which is kind of counter-intuitive...), yet it would seem to make sense that you have to program the ECM. Having a key that can't open the glove box or trunk, and that can't be used to program another key to the ECM, yet that can start the car, has value.
Local dealership wants for a valet $55 (if in stock) or $75 (if they have to order it), and $60 (1/2-hour) to program it as a valet. Found a genuine blank (dealership) on eBay for $32, will have it cut locally. Still trying to find the programming instructions for using a master to make a valet... master to master is all over the place, yet no master to valet. All else fails, I'll pay the $60 to have a true valet key programmed by the dealership.
Old 03-25-16, 03:36 PM
  #119
sbagdon
sbagdon's Avatar
Default No luck with keys and remotes
'98 GS400.
Received the master and valet key yesterday. Had the master cut by a local locksmith, and tried to program the master with the original master, and just can't get it to program. Probably tried 20x... insert/no-turn existing master, security light goes out, gas 5x, brake 6x, remove existing master, insert new master, gas 1x. The security light stays out, then about 10sec later the security light starts blinking, as if it is out of programming mode. The blinking never stops, so it doesn't appear to be programming. Tried 20x, different pace/speed, etc, just can't get it to work... thoughts?
Also, can't put the KRE in to programming mode, tried as many times, the locks never cycle once, after the key-to-on-then-remove. again.. what am I doing wrong?
Funny thing is... I can at least set the seat memories. So the mirrors / steering wheel / seat will go to their assigned locations. At least that works...
Old 03-30-16, 02:23 PM
  #120
cstrong45
cstrong45's Avatar
The write up works, however to get the remote programmed I had to use the Master Key with the programming in it. The last step was to push the lock and unlock buttons on the NEW key...it worked just great.
The ignition programming was fine too, just have to make sure you stomp on the gas pedal and brake very fast.
Quick Reply: KEY PROGRAMMING for 98-05 gs300 400 430
