01 gs300 blower inop
I have searched forums for hours to no avail so here is my problem. Blower fan quit blowing display reads high got to the fan checked voltage it's like .0050 on volt meter checked fan obstruction noting there put 12 volts to fan it works fine. Checked fuses, blower control module there's no voltage entering it except .0050 which certainly is not enough to power the blower checked relay near both kick panels everything good there so if someone could point me to next step would be appreciated. In other threads read about resistor but don't know where it is. So guys please help
Huey
Huey
Checked voltage to control blower motor which is the little box 0 voltage on white/black wire 0 voltage on blue wire depending on the fan speed voltage on little wire or signal wire on low its .0016 on high it's at .0050 I'm not real smart but guessing the wh/bk wire being ground and blue being hot or 12 vo. Losing voltage where ever blue wire feeds from.
Check fuse and relay. If they are both working, you got an open wire to the blower motor. Easy.
I have checked fuse and relay which is located pass. Kick panel beside the defog relay still no voltage btw the wires going to blower motor control which is wh/bk, blue/bk and little wire blue/red it reads .0050 with fan on high. Which one of the big wires going to blower motor control is ground, or hot help me please
95silversc
Performance & Maintenance
02-22-10 09:49 PM
