Gs300 washer nozzles converted to 03+ es300 washer nozzles
I mine as well share my knowledge, I just bought 03+ es300 washer nozzles. Converting from a stream spray to a fan spray since our nozzles are known to be easily clogged. Price I paid were $15 each. Sorry no pics yet
Part #85381-33060-C0. This is for the black color
i bought the universal nozzle kit from autozone for 16 bucks. sprays way better than oem nozzles. only took 10 minutes to switch out. comes with a key to adjust the spray direction.
Can we get a quick tutorial on how to do this? Can't seem to find much about it. I suppose I could start poking around on my car but I would rather ask first!
Thanks much.
Thanks much.
Pretty sure theyre just held into the hood with press clips. Just get at the underside and pop them out, disconnect the lines and install the new ones. At least that's what I recall when I poked around a while back, I'm sure someone will correct me if I'm wrong.
Ok thinking I might be wrong on the install, maybe the op can fill everybody in on the install procedure.
wait so u bought the nozzle and not the whole covering/caps? i dont really use my washer fluid that often but this is definitely good to have over the stream spray
