Question about aftermarket wheel Lug Nuts and Hub Rings
Old 05-03-12, 04:07 PM
tresvatos
tresvatos's Avatar
Default Question about aftermarket wheel Lug Nuts and Hub Rings
I have a question i want to try to get a n answer to before i tear something up. I recently purchased some American racing Casinos, which have the GS 5x114.3 bolt pattern. I have seen on the forums that alot of people say to use the tapered, or acorn style lug nuts in the left side of the picture. The ones in the middle have the shank and will fill the excess area in the wheel bolt hole, while snugging the wheel to the hub. I would like to use the nuts that have the shank, but i want to be sure they are safe. Another issue i woud like to clear up is the small gap betwwn the wheel hub bore and the hub diameter . Do i need to get any type of Hub Centric rings in order to properly center the new wheels..? Thanks for any advice
Attached Thumbnails Question about aftermarket wheel Lug Nuts and Hub Rings-photo.jpg   Question about aftermarket wheel Lug Nuts and Hub Rings-photo-2.jpg
Old 05-03-12, 05:50 PM
YxUxMADDDD
YxUxMADDDD's Avatar
Yes you do. Most, if not all, after market wheels would require hub centric rings to avoid any vibrations unless you get a rim that is SPECIFICALLY MADE for your car (i believe the hub bore is 60.1mm) and I'm not talking about the 5x114.3 bolt pattern. As far as the lug nuts, I believe you can use any tuner nuts except factory cause they're just do d**n fat!
Old 05-03-12, 06:52 PM
13loody
13loody's Avatar
I bought some hub rings for my wheels. I went with the plastic stuff because it was cheap and supposedly metal ones may fuse. Put on some antiseize if you do go with metal though.
Old 05-04-12, 06:59 PM
tresvatos
tresvatos's Avatar
Ok, so I'm good with the nuts i'm using, just need to locate some 60.1mm hub rings- thanks for the input- I may have to get those skinny spline tapered lug nuts though, because I cant get a regular tire tool end in the aftermarket lugnut holes- does anyone see a problem there? Thanks
Old 05-04-12, 07:04 PM
abounly
abounly's Avatar
I dont think you can use stock lug nuts for any aftermarket style rims. They are too fat as a member mentioned already. I have a cheap set for sale if your interested. There will be a key with the package that you can use to as an extender for your stock tire tool
Old 05-05-12, 01:32 AM
tresvatos
tresvatos's Avatar
Can you send me a picture please.
Old 05-05-12, 08:42 AM
99 GS3
99 GS3's Avatar
You must use aftermarket acorn nuts for aftermarket wheels. Do not use oem style lug with flanges on those wheels.
You can get a 20 pack of lugs that are splined, hex, inverted hex, hepta, or various other locknut patterens at autozone, advance, oreilly's, ebay or whatever for like ~$20 or so that will come with a thin wall socket to fit in deep aftermarket pad holes. The size you need is 12x1.50mm
Or you can get some awesome titanium nuts from www.dressupbolts.com
Old 05-05-12, 10:20 AM
perry05g35
perry05g35's Avatar
Best bet is to take your car to your nearest discount tire they will have the appropriate lug nut for your wheel in stock the ebay, autozone lug nuts are heavy.
Old 05-05-12, 03:43 PM
LexiBlue
LexiBlue's Avatar
advance have them m12 by 1.5
Old 05-05-12, 04:01 PM
99 GS3
99 GS3's Avatar
True, the autozone/advance lugs are steel..
Ebay has everything so it's a bit vauge to say they are heavy since you can get ray's titanium lugs for $400 on ebay, or you can get cheap $15 aluminum lugs as well..
Be leery of running aluminum lugs if they are not forged.
Old 05-06-12, 12:01 PM
SorrGwa
SorrGwa's Avatar
there are 3 types of lugs that i have seen.
shank (oem alloy wheel)
ball seat (most honda's and steelies)
tappered (mainly aftermarket)
Old 05-07-12, 02:08 AM
tresvatos
tresvatos's Avatar
I have read all of the suggestions..thanks for the advice!
Benoit
Wheels, Tires & Brakes Forum
04-25-19 01:49 AM
pb4ugo
07-05-17 04:25 PM
vtrusty
05-25-11 05:40 AM
IS-SV
Suspension and Brakes
40
05-25-11 05:35 AM
radicalrev
03-27-08 01:39 AM
Quick Reply: Question about aftermarket wheel Lug Nuts and Hub Rings
